Variants add to basket
I am setting up a shop for a small grocery. Each product e.g. a pickle jar is available in different sizes/variants e.g. 400ml, 720ml, 1700ml etc. I can see each size in the detail view section however I can put only the last selected item/variant into the basket. Is it possible to put all selected variants into the basket?
Aimeos 18.10.9 / Typo3 8.7.27
Thanks!
Thanks!
Re: Variants add to basket
any feedback on this?
Thanks!
Thanks!
Only if you list all variants like this:
https://twitter.com/aimeos/status/1141651185755185152
The Aimeos 19.7 release already contains an alternative template for that.
