GetRefItems from Json API
QuốcTrungNguyễnHoàng
Post by QuốcTrungNguyễnHoàng » 13 Aug 2019, 10:08
Hi, I'm try to get preview URL for product from JSON API product resource. My Json Reponse here:
How can i map references object Id from Relationship array with object id from Included Array not use loop for every product ?
Re: GetRefItems from Json API
Post by aimeos » 13 Aug 2019, 11:54
The jsonapi.org standard doesn't allow to structure the "included" array in advance, so the best way is to loop over the "included" array once at the beginning and create an object tree of
	"<domain>": {
		"<id>": <entry>,
e.g.
let map = {};
for( let entry of included ) {
	map[entry['type']][entry['id']] = entry;
Afterwards, you can do a quick lookup when iterating over the products.
Post by QuốcTrungNguyễnHoàng » 14 Aug 2019, 04:41
Thank for your help,
Another problems,
I use Product JSON API Resource with f_catid filter, it not return promotion products in response
Post by aimeos » 14 Aug 2019, 07:26
Use promotion for f_listtype to get the promotional products of a category
