Translation of mshoplib
cnoelker
Post by cnoelker » 12 Aug 2019, 11:56
I am able to provide my own translations for strings in the client domain. However, I did not yet find a way to translate the strings in the files in this directory:
Libraries/aimeos/aimeos-core/lib/mshoplib/i18n/
I tried to create en.po and de.po files (and started msgfmt) in
Resources/Private/Extensions/[my extension]/client/i18n/mshop
and also in
Resources/Private/Extensions/[my extension]/lib/mshop
None of these worked. Where is the proper location?
I also tried to provide the translation via typoscript:
plugin.tx_aimeos.settings.i18n.de.0 {
domain = mshop
string = Products out of stock
trans = Das Produkt ist nicht mehr in ausreichender Zahl auf Lager.
Still no luck. (Tried with domain mshoplib, too.)
How can I translate the content of mshoplib ?
Claudia
Re: Translation of mshoplib
Post by aimeos » 12 Aug 2019, 20:12
The string you want to translate is used here in the code:
https://github.com/aimeos/aimeos-core/b ... ck.php#L69
For .po files (and the files without extension created by msgfmt) the correct location in your own extension is:
Resources/Private/Extensions/[my extension]/lib/custom/i18n/
You translation for the string via TypoScript is correct:
    domain = mshop
Only make sure that you don't overwrite that translation afterwards by another one (check in TypoScript Object Browser if the translation is still there).
cnoelker
Post by cnoelker » 13 Aug 2019, 07:41
Thank you. It works now for translating "Products out of stock", but not for "product.stock.notenough". Both are in the same file:
Translation in en.po
msgid "Products out of stock"
msgstr "Some products are out of stock in the requested quantity."
msgid "product.stock.notenough"
msgstr "Quantity was reduced to max. available quantity."
Translation in de.po
msgstr "Produkt nicht mehr in ausreichender Anzahl auf Lager."
msgstr "Menge wurde auf max. verfügbare Menge reduziert."
Any clue for this?
Post by aimeos » 13 Aug 2019, 09:59
The translation domain for the plugin codes is "mshop/code":
https://github.com/aimeos/ai-client-htm ... #L701-L716
cnoelker
Post by cnoelker » 13 Aug 2019, 10:23
Why doesn't this work then?
domain = mshop/code
string = product.stock.notenough
trans = Menge wurde auf max. verfügbare Menge reduziert.
plugin.tx_aimeos.settings.i18n.en.0 {
domain = mshop/code
trans = Quantity was reduced to max. available quantity.
I checked in the TypoScript object browser: These settings are available.
Post by aimeos » 14 Aug 2019, 07:50
What doesn't work? Your TypoScript code doesn't change the translation of the string that belongs to the code
cnoelker
Post by cnoelker » 14 Aug 2019, 07:53
The translation does not work. I tried in the .po files and in TypoScript, but nothing works out.
Post by aimeos » 14 Aug 2019, 07:54
You mean "product.stock.notenough" isn't translated at all?
cnoelker
Post by cnoelker » 14 Aug 2019, 08:29
The translation is the standard provided by aimeos. However, I would like to change the standard translation. And although I tried different ways, I did not succeed.
Post by aimeos » 14 Aug 2019, 08:32
So this doesn't change the translation of the error message at all?
plugin.tx_aimeos.settings.i18n.de.1000 {
    domain = mshop/code
    trans = Menge reduziert
plugin.tx_aimeos.settings.i18n.en.1000 {
    domain = mshop/code
    trans = Quantity reduced
