Explanation of aimeos package source code
I found there are a lot of aimeos documents but I cannot find the one will help me to understand easily aimeos package.
Please let me know if there is any documentation on the explanation of aimeos package source code such as which file do what.
I think it will save a lot of time for a new aimeos programmer.
Thank you very much in advance.
Mauphung
Mauphung
Re: Explanation of aimeos package source code
A good start is the architectural model of Aimeos:
https://aimeos.org/docs/Developers/Software_stack
Thank you for your response. I’m Aimeos newbie. I try to build an example with the following steps:
1. Install latest Laravel 5.8.*
2. Install Aimeos package
Laravel e-commerce package for professional, ultra fast online shops, complex B2B applications and #gigacommerce https://aimeos.org/Laravel
https://github.com/aimeos/aimeos-laravel
3. I run server and access to /shop, it's OK
4. I want to create myshop and access with URI /myshop by doing following steps:
4.1 In config/shop.php, I add the indexes to get the html from my ExampleController to my view myshop.blade.php
'page' => [
'myshop' => array('basket/mini', 'catalog/filter', 'catalog/lists'),
4.2 In my ExampleController, I add myshop method:
class ExampleController extends Controller
public function mobishop()
foreach( app( 'config' )->get( 'shop.page.mobishop' ) as $name )
$params['msheader'][$name] = Shop::get( $name )->getHeader();
$params['msbody'][$name] = Shop::get( $name )->getBody();
// do some more stuff
return \View::make('mobishop', $params);
4.3 In my routes\web.php, I add a route “/myshop”
Route::get('/myshop', 'ExampleController@myshop')→name('myshop');
4.4 I create my view resources\views\myshop.blade.php to display html data get from my ExampleController:
@extends('shop::base')
@section('aimeos_header')
<?= $msheader['basket/mini'] ?>
<?= $msheader['catalog/filter'] ?>
<?= $msheader['catalog/lists'] ?>
@stop
@section('aimeos_head')
<?= $msbody['basket/mini'] ?>
@stop
@section('aimeos_nav')
<?= $msbody['catalog/filter'] ?>
@stop
@section('aimeos_body')
<?= $msbody['catalog/lists'] ?>
@stop
4.5 I access /myshop and I get myshop page on screen. It's OK.
4.6 When I click on first product item, it display the detail of a selected product with URL:
http://localhost:8000/shop/Demo_article/0
I check in a folder vendor\aimeos\aimeos-laravel\src\Aimeos\Shop\Controller, I don’t see a Controller of Demo_article and I cannot find it anywhere in the aimeos package.
My questions are followings:
1/ Where can I find Aimeos Demo in Aimeos package? And how to pass the item id?
2/ Do I need to install these two additional packages Aimeos frontend controller and Aimeos e-commerce HTML client components?
https://github.com/aimeos/ai-controller-frontend
3/Is there any tutorial showing how to program build the Laravel application with Aimeos package, Step-by-Step approach with the examples?
Thank you in advance for your response.
'page' => [
@stop
@stop
@stop
@stop
This are virtual URLs that contain the product name which is used to resolve the product and show the details.nguyen.phung wrote: ↑20 Aug 2019, 13:51 4.6 When I click on first product item, it display the detail of a selected product with URL:
If you only want to use "/myshop" instead of "/shop", you can change the route prefix in your ./config/shop.php ("routes" section):
'default' => ['prefix' => 'myshop', 'middleware' => ['web']],
No, they are automatically installed. You can see them if you run "composer show"nguyen.phung wrote: ↑20 Aug 2019, 13:51 2/ Do I need to install these two additional packages Aimeos frontend controller and Aimeos e-commerce HTML client components?
This page contains more or less a list of articles to install, configure and extend your Aimeos installation step-by-step:nguyen.phung wrote: ↑20 Aug 2019, 13:51 3/Is there any tutorial showing how to program build the Laravel application with Aimeos package, Step-by-Step approach with the examples?
https://aimeos.org/docs/Laravel
