Add price after pressing "add to basket" button
lucadambros
Post by lucadambros » 22 Aug 2019, 08:01
I have a product without a price. How can I add the price after pressing the "add to basket" button?
Thank you very much
Re: Add price after pressing "add to basket" button
Post by aimeos » 22 Aug 2019, 08:13
What's your use case?
Aimeos contains a custom price attribute where customers can enter an arbitrary price, e.g. when buying vouchers and the price is added to the basket product then
lucadambros
Post by lucadambros » 22 Aug 2019, 08:30
Use case:
The product can have a strange type of calculation of the price that depends on external factors like the betting system or something like creation of gadgets.
Post by aimeos » 22 Aug 2019, 09:08
Write a decorator for the basket frontend controller, that calculates the price and adds it to the product item:
https://github.com/aimeos/ai-controller ... /Decorator
lucadambros
Post by lucadambros » 22 Aug 2019, 09:12
What happens if another user adds the same product but has a different price?
Post by aimeos » 22 Aug 2019, 09:15
What happens in your decorator and how the prices are calculated is totally up to you (and your external factors).
If you have configurable products (with additonal options that have an additional price), you can also assign one or more config attributes with own prices to the product. Customers can then choose the options they want and the total price of the product is calculated automatically.
lucadambros
Post by lucadambros » 22 Aug 2019, 09:36
aimeos wrote: 22 Aug 2019, 09:15 If you have configurable products (with additonal options that have an additional price), you can also assign one or more config attributes with own prices to the product. Customers can then choose the options they want and the total price of the product is calculated automatically.
I know that but i don't have configurable products.
Creating an identical product with the price I calculate while adding it into the basket, can be a solution?
Post by aimeos » 22 Aug 2019, 09:40
lucadambros wrote: 22 Aug 2019, 09:36 Creating an identical product with the price I calculate while adding it into the basket, can be a solution?
Sure, the basket decorator will be your friend in that case :-)
lucadambros
Post by lucadambros » 22 Aug 2019, 09:51
Thank you very much!
lucadambros
Post by lucadambros » 22 Aug 2019, 13:39
Last question: how can I change the value of a param into the decorator?
I have the array
$view->param( 'b_prod' );
How can I change the value of that?
