Error While Update 2018.10.* to 2019.07
awaidqureshi
Post by awaidqureshi » 23 Aug 2019, 07:56
While Running This Command Geeting Error :
composer require aimeos/aimeos-laravel
Using version ^2019.07 for aimeos/aimeos-laravel
./composer.json has been updated
Loading composer repositories with package information
Updating dependencies (including require-dev)
Your requirements could not be resolved to an installable set of packages.
Problem 1
- aimeos/aimeos-laravel 2019.07.1 requires aimeos/aimeos-core 2019.07.* -> satisfiable by aimeos/aimeos-core[2019.07.1, 2019.07.2, 2019.07.3, 2019.07.4, 2019.07.5, 2019.07.6, 2019.07
.7, 2019.07.8, 2019.07.9, 2019.07.x-dev].
- aimeos/aimeos-laravel 2019.07.2 requires aimeos/aimeos-core 2019.07.* -> satisfiable by aimeos/aimeos-core[2019.07.1, 2019.07.2, 2019.07.3, 2019.07.4, 2019.07.5, 2019.07.6, 2019.07
- aimeos/aimeos-laravel 2019.07.3 requires aimeos/aimeos-core 2019.07.* -> satisfiable by aimeos/aimeos-core[2019.07.1, 2019.07.2, 2019.07.3, 2019.07.4, 2019.07.5, 2019.07.6, 2019.07
- aimeos/aimeos-laravel 2019.07.x-dev requires aimeos/aimeos-core 2019.07.* -> satisfiable by aimeos/aimeos-core[2019.07.1, 2019.07.2, 2019.07.3, 2019.07.4, 2019.07.5, 2019.07.6, 201
9.07.7, 2019.07.8, 2019.07.9, 2019.07.x-dev].
- aimeos/aimeos-core 2019.07.x-dev requires ext-intl * -> the requested PHP extension intl is missing from your system.
- aimeos/aimeos-core 2019.07.9 requires ext-intl * -> the requested PHP extension intl is missing from your system.
- aimeos/aimeos-core 2019.07.8 requires ext-intl * -> the requested PHP extension intl is missing from your system.
- aimeos/aimeos-core 2019.07.7 requires ext-intl * -> the requested PHP extension intl is missing from your system.
- aimeos/aimeos-core 2019.07.6 requires ext-intl * -> the requested PHP extension intl is missing from your system.
- aimeos/aimeos-core 2019.07.5 requires ext-intl * -> the requested PHP extension intl is missing from your system.
- aimeos/aimeos-core 2019.07.4 requires ext-intl * -> the requested PHP extension intl is missing from your system.
- aimeos/aimeos-core 2019.07.3 requires ext-intl * -> the requested PHP extension intl is missing from your system.
- aimeos/aimeos-core 2019.07.2 requires ext-intl * -> the requested PHP extension intl is missing from your system.
- aimeos/aimeos-core 2019.07.1 requires ext-intl * -> the requested PHP extension intl is missing from your system.
- Installation request for aimeos/aimeos-laravel ^2019.07 -> satisfiable by aimeos/aimeos-laravel[2019.07.1, 2019.07.2, 2019.07.3, 2019.07.x-dev].
To enable extensions, verify that they are enabled in your .ini files:
- C:\xampp\php\php.ini
You can also run `php --ini` inside terminal to see which files are used by PHP in CLI mode.
Installation failed, reverting ./composer.json to its original content.
Re: Error While Update 2018.10.* to 2019.07
Post by aimeos » 23 Aug 2019, 08:55
You need to install the php-intl extension for Aimeos 2019.x
awaidqureshi
Post by awaidqureshi » 23 Aug 2019, 14:04
Again Got The Different Error
aimeos wrote: 23 Aug 2019, 08:55 You need to install the php-intl extension for Aimeos 2019.x
Problem 1
- Conclusion: don't install aimeos/aimeos-laravel 2019.07.3
- Conclusion: don't install aimeos/aimeos-laravel 2019.07.2
- Conclusion: don't install aimeos/aimeos-laravel 2019.07.1
- Conclusion: remove aimeos/ai-admin-jqadm 2018.10.18
- aimeos/aimeos-laravel 2019.07.x-dev requires aimeos/ai-admin-jqadm 2019.07.* -> satisfiable by aimeos/ai-admin-jqadm[2019.07.1, 2019.07.2, 2019.07.3, 2019.07.4, 2019.07.5, 2019.07.
x-dev].
- Can only install one of: aimeos/ai-admin-jqadm[2019.07.1, 2018.10.18].
- Can only install one of: aimeos/ai-admin-jqadm[2019.07.2, 2018.10.18].
- Can only install one of: aimeos/ai-admin-jqadm[2019.07.3, 2018.10.18].
- Can only install one of: aimeos/ai-admin-jqadm[2019.07.4, 2018.10.18].
- Can only install one of: aimeos/ai-admin-jqadm[2019.07.5, 2018.10.18].
- Can only install one of: aimeos/ai-admin-jqadm[2019.07.x-dev, 2018.10.18].
- Installation request for aimeos/ai-admin-jqadm (installed at 2018.10.18) -> satisfiable by aimeos/ai-admin-jqadm[2018.10.18].
Post by aimeos » 24 Aug 2019, 08:59
In existing installations, you should change the versions manually from ~2018.10 to ~2019.07 in your composer.json and run "composer update" instead.
If it still doesn't work, you can delete the official Aimeos extensions in the ./ext/ folder. Also make sure that you generate a new Aimeos extension for your project and copy the files you've changed to your new project extension.
