No items appear at the list
Amber
Post by Amber » 10 Sep 2019, 02:36
Why do I create a new item in the admin, but I can't see it at the list? (https://localhost/list)
Re: No items appear at the list
Post by aimeos » 10 Sep 2019, 07:10
You haven't probably added it to a category so it won't show up.
Amber
Post by Amber » 12 Sep 2019, 06:46
I create a new category "test", but product don't be added to a category.
Post by aimeos » 12 Sep 2019, 07:32
From your screenshots we can't see that the "test" category was really created.
Amber
Post by Amber » 12 Sep 2019, 08:48
Category list is empty. But the database has data. I use postgresSql.
Post by aimeos » 12 Sep 2019, 09:19
Can you check the browser console if there are any errors? Maybe your web server doesn't answer to OPTIONS requests.
Amber
Post by Amber » 17 Sep 2019, 04:09
I fix OPTIONS requests 500 error, but category list is still empty.
nginx
location / {
       if ($request_method = OPTIONS ) {
	       add_header Access-Control-Allow-Origin "*";
	       add_header Access-Control-Allow-Methods "POST, GET, PUT, DELETE, PATCH, OPTIONS";
	       add_header Access-Control-Allow-Headers "origin, content-type, accept,DNT,X-CustomHeader,Keep-Alive,User-Agent,X-Requested-With,If-Modified-Since,Cache-Control,Content-Type";
	       add_header Access-Control-Allow-Credentials "true";
	       add_header Content-Length 0;
	       add_header Content-Type text/plain;
	       return 200;
    try_files $uri /index.php$is_args$args;
Post by aimeos » 17 Sep 2019, 08:17
What is now returned to the browser? Can you post the made requests and the response for fetching the categories?
Amber
Post by Amber » 18 Sep 2019, 01:27
The browser is returned 200.
response
access-control-allow-credentials: true
access-control-allow-headers: origin, content-type, accept,DNT,X-CustomHeader,Keep-Alive,User-Agent,X-Requested-With,If-Modified-Since,Cache-Control,Content-Type
access-control-allow-methods: POST, GET, PUT, DELETE, PATCH, OPTIONS
access-control-allow-origin: *
content-length: 0
content-type: text/plain
date: Tue, 17 Sep 2019 09:53:23 GMT
server: nginx/1.13.5
status: 200
request
:authority: localhost
:method: OPTIONS
:path: /admin/default/jsonadm
:scheme: https
accept: application/json, text/javascript, */*; q=0.01
accept-encoding: gzip, deflate, br
accept-language: zh-TW,zh;q=0.9,en-US;q=0.8,en;q=0.7,zh-CN;q=0.6
cache-control: no-cache
cookie: _ga=GA1.2.1879821586.1542254114; __utmc=44967156; _ga=GA1.3.1879821586.1542254114; __utmc=50244577; __cfduid=d92079f013479d914db998cb7f7f3f4a91545033294; __utmz=50244577.1548838723.15.15.utmcsr=35.201.218.27|utmccn=(referral)|utmcmd=referral|utmcct=/123.html; __utmz=44967156.1552459011.104.23.utmcsr=lebesgue.localhost|utmccn=(referral)|utmcmd=referral|utmcct=/demo/mobile/5; bdshare_firstime=1557993905979; PHPSESSID=b4a2805d804ddabbf28e439ee359ca85; __utma=50244577.1879821586.1542254114.1550809339.1563522356.17; __utma=44967156.1879821586.1542254114.1566877732.1567740605.212; _gid=GA1.2.1844355449.1568684331; XSRF-TOKEN=eyJpdiI6IkdUNjgxUE42U3NLQzIrcjVcL1A4dENRPT0iLCJ2YWx1ZSI6Ik5HRVhSRFFkSGx5TExqZ1RWK25uZ0NEM0xwM1pIQTc3Q1d2bE91NUZISUtRTkJ3aEpOdE9BQmNuaDFsMEM4aTd4Y3ExdkhydnFNZ1l6N3NLTlZjekRnPT0iLCJtYWMiOiI3ZGYyMzcxZWE4MDI5ODhlZTdiYjQxYWQ0MGNiNTcxNTYxNWVlYjIwOTM5OTkwZDM2Mjc3OWExMWUyMmMwNWIxIn0%3D; vnvideogo_ads=eyJpdiI6IjlSaE1jK0orZHBVS3JQQlVPc2NibkE9PSIsInZhbHVlIjoiTytzOG1ndFZPOGtucmRPa0pTXC80dTJ2ckYxbHJrcndhSWVcL3pwOXk1OEVveWRWR0psRGpLRmgrdVR5OUQ2UHRtYmsxNHBVOE42THVKRVRsaVV1ZXFVQT09IiwibWFjIjoiZDE2MjQxZjI1Yzk4ZmUzMDYyMDcyNWEzODYzNmY1ZGU3ZGU5MzcwOTIyYTU1NzdjYWU1ZDhhY2VlOTA5ZDBiNiJ9
origin: https://localhost
pragma: no-cache
referer: https://localhost/admin/default/jqadm/s ... og?lang=zh
sec-fetch-mode: cors
sec-fetch-site: same-origin
user-agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/76.0.3809.132 Safari/537.36
x-requested-with: XMLHttpRequest
Post by aimeos » 18 Sep 2019, 09:59
The request is for the OPTIONS method, there should be something for:
GET /admin/default/jsonadm/catalog
