Change Button Link
mahsun21
Change Button Link
Post by mahsun21 » 09 Sep 2019, 12:37
I have a question about the button link. If I change the "URL target" then the whole link of the product changes. So If i click on it then it follows the link. But is there a way that if i click on the product (in the shop page) that it follows to the page of the product and then i click on the button "in the cart" that it follows the "URL target"?
It would be nice to find a solution!
Thank you!
Re: Change Button Link
Post by aimeos » 09 Sep 2019, 14:56
The values in the URL target must be IDs of TYPO3 pages.
To change the URL when adding a product to the the basket, go into the the Catalog Detail configuration and change the page reference to the basket page.
mahsun21
Post by mahsun21 » 11 Sep 2019, 09:26
Where can i find it?
I'm new to aimeos ^^
I can not handle finding files yet ^^
Post by aimeos » 11 Sep 2019, 16:20
- Go to the page that contains your Aimeos catalog detail plugin
- Click on the pencil button of the Aimeos catalog detail plugin
- Go to the "Plugin" tab
- Find the page reference for the basket page
- Remove the existing page reference
- Click on the folder button to select the new page Aimeos should post the data for the basket to
mahsun21
Post by mahsun21 » 12 Sep 2019, 13:53
Is there a way to change that in a csv file and use a external url?
I use affiliate products.
Post by aimeos » 13 Sep 2019, 09:18
No, for affiliate systems, you need another approach. The ai-sites extension for the Aimeos company allows you to create a site tree where each affiliate site inherits the products from the main site. If a customer buys from an affiliate site, you and your affiliate can see the orders and you know to which affiliate it belongs.
Required extension: https://aimeos.com/extensions#c436
