Short description - HTML
mahsun21
Post by mahsun21 » 23 Sep 2019, 11:11
Hello
can I use html code in the shortdescription of an product?
Thank you!
Re: Short description - HTML
Post by aimeos » 24 Sep 2019, 05:32
Yes, you can
mahsun21
Post by mahsun21 » 24 Sep 2019, 13:37
Even if I import my products via csv?
Do I have to use a special tag or anything like that to import it as a code and not normal text?
Post by aimeos » 24 Sep 2019, 20:18
Also in CSV imports. HTML tags are not handled differently, they are just normal tags. In short texts, they are not escaped with HTML entities like done for other texts.
