Extend order table for data import/export
- Expert
I need to export and import orders between aimeos and external software. For this I need filed in order table, it is something like id from external software. Please, don't ask me why I do it so - it is task feature. I didn't see the filed for this purpose in order like 'code' in product. So I am only asking in in which table can I add new field, mshop_order or mshop_order_base ? Or I may use some existing field for this ?
Thank you very much !
Re: Extend order table for data import/export
In mshop_order_base there's a field named "customerref" you can use for that purpose:
https://github.com/aimeos/aimeos-core/b ... er.php#L34
