How to use the Stripe hosted checkout page
Re: How to use the Stripe hosted checkout page
Currently, the Omnipay driver seems to support Charge and Intend API only:
https://github.com/thephpleague/omnipay ... asic-usage
You could create a PR for the Omnipay Stripe driver that handles the checkout page API.
Hello mdv2, did you manage to do it the way you wanted? I need to do the same thing. Can you post as you did?
