DB user table email required
kuoyehs
Post by kuoyehs » 09 Oct 2019, 09:58
My project has multiple way to register, ex: email, facebook, mobile, but in aimeos email in user table is required. How can I set the mail to nullable when I only want user to register and login using facebook or mobile phone?
Re: DB user table email required
Post by aimeos » 09 Oct 2019, 11:41
Which integration are you using? In Laravel for example, the e-mail is required and I don't know if you can change that.
Aimeos is using the e-mail address by default because it's required for sending order confirmation e-mails. If you want to sell something, you have to retrieve the e-mail address of the user (e.g. from Facebook) or request it directly from the user.
kuoyehs
Post by kuoyehs » 14 Oct 2019, 03:48
The order confirmation can show on my website or app, and not send e-mail.
Because the database use the same user table, the user table in my project has set mail to nullable, I want to know aimeos how to set mail nullable.
Post by aimeos » 14 Oct 2019, 15:43
You can change the definition of the email column in the users table to allow NULL values (https://aimeos.org/docs/Developers/Libr ... ing_tables) but e.g. the admin interface treats that column as required. Not sure if it wouldn't be easier to add a fake e-mail address instead.
kuoyehs
Post by kuoyehs » 16 Oct 2019, 08:33
./lib/custom/setup/default/schema/ don't have file to change column on user table.
But the method has to change package, how to set column on "config/shop.php" or other method ex: extension?
Post by aimeos » 17 Oct 2019, 07:33
The ai-laravel extension defines the columns for the "users" table:
https://github.com/aimeos/ai-laravel/bl ... stomer.php
