Problems with loading images on frontend
Re: Problems with loading images on frontend
Is there any JS error before? Can you post all errors from the browser console?
HI
We are still blocked for 2 weeks now and fighting with this problem. We cannot see any reason why this doen't work how it should.
I send you some more information of my expert:
Same page, but different behavior for images loaded in visible screen portion and that are loaded in the non-visible screen.
The error is in the core of aimeos. I feel that one of aimeos script is removing the src for the non-visible images, but unable to set it when it becomes visible
pls see the two attachments.
thanks
thanks
- src_code.png (203.75 KiB) Viewed 1564 times
- no_src_code.png (82.96 KiB) Viewed 1564 times
Hope you can solve the problem today............
Please remove the loading="lazy" in your templates. This causes problems in Chrome and has been removed from all templates in 19.7.3 I think. Templates you've already copied and modified can still contain the attribute you have to remove.
