Search bar and category search not working properly
SupportMantik
Post by SupportMantik » 14 Oct 2019, 16:07
We are using Aimeos v.18.10.0. and have 2 problems with the search function:
For example:
we have categories:
- AUDI (products: A3, A6, A8)
- BMW (products: X5, X6, X7)
- MERCEDES
1. problem:
When we type into the products search bar an "AUDI" product, for example "Audi A6", the search works fine.
But if we click after that onto a category, for example "BMW", we receive the message "Audi A6 no results" (it remembered the search term from the search bar, even if that are different categories - AUDI/BMW).
2. problem:
for some categories, for example "OPEL", all products are listed. But if we type a product name into the search bar, we receive that there are no results.
Re: Search bar and category search not working properly
Post by aimeos » 14 Oct 2019, 17:11
Did you set a default category in your catalog list plugin? If yes, remove it to get all results.
SupportMantik
Post by SupportMantik » 15 Oct 2019, 10:41
Thanks. I have tried it. But it did not solve my problem.
My search is still very 'buggy'
Post by aimeos » 15 Oct 2019, 10:45
Is the search term still part of the URL?
Post by aimeos » 17 Oct 2019, 07:31
Best option would be to unset the "f_search" parameter here to avoid that issue:
https://github.com/aimeos/ai-client-htm ... hp#L25-L65
