Problems with loading images on frontend
Re: Problems with loading images on frontend
Post by aimeos » 10 Oct 2019, 10:17
Is there any JS error before? Can you post all errors from the browser console?
einmaku
Post by einmaku » 16 Oct 2019, 14:42
HI
We are still blocked for 2 weeks now and fighting with this problem. We cannot see any reason why this doen't work how it should.
I send you some more information of my expert:
Same page, but different behavior for images loaded in visible screen portion and that are loaded in the non-visible screen.
The error is in the core of aimeos. I feel that one of aimeos script is removing the src for the non-visible images, but unable to set it when it becomes visible
pls see the two attachments.
thanks
einmaku
Post by einmaku » 17 Oct 2019, 06:29
Hope you can solve the problem today............
Post by aimeos » 17 Oct 2019, 07:44
Please remove the loading="lazy" in your templates. This causes problems in Chrome and has been removed from all templates in 19.7.3 I think. Templates you've already copied and modified can still contain the attribute you have to remove.
