Create new category
Create new category
I am new to Aimeos shop. This why I have this question maybe.
I have category "Home" and after that on the second level I have 2 other subcategories.
Now I want to create another category called "Test" on first level and then also 2 other subcategories. See pics in the attachment.
How can I do that?
Typo3 version 9.5
BR
Steven
How can I do that?
Typo3 version 9.5
BR
Steven
- Capture_.PNG (136.26 KiB) Viewed 1133 times
Re: Create new category
There can only be one category tree with one root node so add all "level 1" nodes below "Home". In the tree template you can remove displaying the "Home" category if you don't want it. Replace
by
in your local copy of https://github.com/aimeos/ai-client-htm ... rd.php#L81
array( $this->treeCatalogTree )
$this->treeCatalogTree->getChildren()
