keyword for products
I would like to define keywords for products, so that when you enter the keywords in the search box the products are found.
How does it work?
Thank your for your help.
aimeos: 2019.07.x-dev
symfony: 4.3
php: 7.2
ubuntu: 18
How does it work?
symfony: 4.3
php: 7.2
ubuntu: 18
Re: keyword for products
You can add a text of type "meta keywords" to your product. That will get indexed and your products will get found if someone searches for that keywords.
That does not work for me unfortunately.
I have rebuild the index with aimeos:job index/rebuild too . That does not help either.
- Sucheergebnis.JPG (22.65 KiB) Viewed 8404 times
- Meta-Keyword Beispiel.JPG (30.01 KiB) Viewed 8404 times
Make sure you use the corresponding language (not "All") and update to 2019.10 please. Think, there was a related bug in 2019.07.
After updating to 2019.10, product search for keywords will work.
Thanks for your help.
