Cache into database
Cache into database
Hello
I try to cache aimeos (laravel) into my database.
There is no manager into ai-cache to do to that.
I tried to configure aimeos to use the standard laravel cache system, but there is no documentation about that anywhere.
I begin to thing Aimeos is not able to do this simple stuff...
So, my question is -> Is that possible to cache aimeos into a database without reprogramming Aimeos.
If not, Why ?
Thank you
If not, Why ?
Thank you
Re: Cache into database
Storing the cached entries into the database is the default but Aimeos uses it's own table (madmin_cache)
Haaa yes indeed, Thank you
So now.
I have a page which is impossible to debug because of the cache.
Event i change URL parameters, the page stay the same.
I tried all commands to clean caches but no way.
My questions is -> What is the best way to desable cache for development area ?
Thanks...
So now.
Thanks...
If you enable these two settings in your ./config/shop.php, no caching will occur at all:
- https://github.com/aimeos/aimeos-larave ... op.php#L65
- https://github.com/aimeos/aimeos-larave ... op.php#L85
