overriding Client\Html\Checkout\Standard\Standard.php
Luis
Post by Luis » 17 Jul 2017, 20:37
I modified the getBody method inside to add new functionality. How and where should I put the new file which originally was in ai-client-html\Client\Html\Checkout\Standard\Standard.php. I have a custom ext/my-client-ext/ and a manifest.php file that includes 'client/html/src'.
Re: overriding Client\Html\Checkout\Standard\Standard.php
Post by aimeos » 18 Jul 2017, 00:42
Rename the file to e.g. Myproject.php and put it into the same directory structure in your own extension (./ext/myext/client/html/src/Client/Html/Checkout/Standard/Myproject.php). Then, configure the new class name (Myproject): https://aimeos.org/docs/Configuration/C ... ndard/name
Luis
Post by Luis » 18 Jul 2017, 16:44
Hey, thanks for the quick response. I'm getting an error when i tried doing this.
(1/1) Exception
Invalid characters in class name "<not a string>"
in Factory.php (line 76)
at Factory::createClient(object(Standard), array('/Users/laravel/ext/ai-client-html' => array('client/html/templates'), '/Users/public/laravel/ext/myproject' => array('client/html/templates')), array('Mycheckout'))
conf/shop.php
'checkout' => array(
'confirm' => array(
'name'=> array('Mylaststep')
'standard' => array(
'name'=> array('Mycheckout'),
namespace Aimeos\Client\Html\Checkout\Standard;
class Mycheckout
namespace Aimeos\Client\Html\Checkout\Confirm;
class Mylaststep
Post by aimeos » 19 Jul 2017, 08:05
The "name" parameter must be the name of the class, not an array with its name.
Luis
Post by Luis » 19 Jul 2017, 18:21
Thanks for the quick response. that worked
aloniwe
Post by aloniwe » 12 Dec 2019, 18:06
Is it working right now? I'm trying to override Catalog\Lists\Standard class from ai-client-html.
I added new 'Mystandard' class into my extension (myext\client\html\src\Client\Html\Catalog\Lists\Mystandard) with same code from ai-client-html.
Also i added config:
	'client' => [
		'html' => [
            'catalog' => [
                'lists' => [
                    'name' => 'Mystandard',
But it's not working.
I get an exception: Class "\Aimeos\Client\Html\Catalog\Lists\Mystandard" not available
Post by aimeos » 13 Dec 2019, 10:51
Did you forgot the ".php" extension in your file name?
-> myext/client/html/src/Client/Html/Catalog/Lists/Mystandard.php
aloniwe
Post by aloniwe » 13 Dec 2019, 16:42
No, my standard class has correct extension (Mystandard.php).
Post by aimeos » 14 Dec 2019, 15:17
Please post your source code so we can see if there's something wrong.
aloniwe
Post by aloniwe » 18 Dec 2019, 16:00
Here my config:
	'client' => [
		'html' => [
            'catalog' => [
                'lists' => [
Here i'm trying to paste my new Standard class:
and exception after:
Aimeos\Client\Html\Exception
