do aimeos-core changes in own distribution
pheeb
Post by pheeb » 17 Aug 2017, 07:19
Hi aimeos!
I want to change the aimeos the ServiceUpdate.php file but I have an own distribution in Typo3 and wan't to know how I can change this file in there, because when I directly change it in the aimeos-core it will be lost in a update. Can you please help me?
here is the path to the ServiceUpdate.php file:
typo3conf/ext/aimeos/Resources/Libraries/aimeos/aimeos-core/lib/mshoplib/src/MShop/Plugin/Provider/Order/ServicesUpdate.php
thanks for helping!
Re: do aimeos-core changes in own distribution
Post by aimeos » 17 Aug 2017, 10:10
We will add the fix for the ServicesUpdate plugin to the Aimeos core so you will get it with the next update.
Generally speaking, if you want to overwrite a class in Aimeos create a new one, extend from the existing, overwrite the method you want to change and configure your new class (either via the factory config or like in this case by using the name of the new class instead of the existing in the plugin tab).
