Overriding Catalog/Base.php class with our own
Hi
I am trying to override this file :
ext/ai-client-html/client/src/Client/Html/Catalog/Base.php
with in my own extension , is that possible? how do I do that in the config/shop.php file? I read the documentation and I didn't find how?
Please help
Please help
- Screen Shot 2017-09-12 at 3.44.33 PM.png (35.85 KiB) Viewed 2068 times
Re: Overriding Catalog/Base.php class with our own
Unfortunately, OOP doesn't allow to overwrite or replace abstract classes other classes extend from. You can only overwrite the methods in the base class in your own class that extends from it.
