error: No item found for conditions: Array ( [attribute.code
I am getting an error that shows up everytime I add a product to cart
No item found for conditions: Array ( [attribute.code] => custom [attribute.domain] => product [attribute.type.code] => price [attribute.type.domain] => product )
do you know what is the issue?
thanks
thanks
Re: error: No item found for conditions: Array ( [attribute.
You have enabled the special price feature for custom prices in your product.
Do you changed or removed the custom price attribute in the administration interface (attribute panel)?
thank you
but where in the admin area I can add that custom price? I didnt remove it
Please have a look at these screenshots. Most probably, you've changed or removed the custom price attribute in the first screen shot
- Attribute for custom product prices
- admin-attribute-price.png (54.02 KiB) Viewed 3272 times
- Custom price feature in product detail panel
- admin-special-price.png (44.84 KiB) Viewed 3272 times
I have the same without custom price, in the backend as in the frontend:
When I want to save changes of product in the backend or when I choose a product for the cart in the frontend, I geht this message.
The last thing I did: change the positions of the product in the catalog list and in the scheduler I was running "Catalog Index Rebuild".
You can always recreate these attributes by running the Aimeos setup
Thank you. Actually there was an attribute missing. Now it works fine.
