Problems with setting up Selections for Products
I am trying to setup the selections for my e-commerce and somewhere I am hitting a snag. I will explain the steps that I am doing and please correct me if I am wrong with any of them.
1. I create the attributes for the product in the product that they relate to.
2. I assign the attributes to the product and change the type to "variant".
3. I create the Selection Product with the Products that have the attributes that I would like to have for a selection.
Is this correct? I am trying to work my way through the instructions on https://aimeos.org/docs/User_Manual/Adm ... l_products and I am not getting something right. Any help would be greatly appreciated.
Re: Problems with setting up Selections for Products
Can't see an error in you description. Can you please go to the simple mode and open your selection product? Go the the "Variants" tab, there should be your articles listed together with the assigned variant attributes. You should use this interface instead because the ExtJS expert mode will be removed in the next version.
I got it on the simple mode. So to verify, the Expert Mode is going away in the next release?
I have add two of variables in place and I am not being able to see the value of both of them on the selector product page. I am only able to part of one. Any suggestions?
- Example of the variant selectors.
- Example.PNG (14.7 KiB) Viewed 3257 times
Yes, the expert mode will go away in the next version.
You mistake is that you think that the variant attributes will both show up in the frontend even if you only have one articles. For your example, you need 4 articles in your selection product: One for each combination of "orientation" and "corner" - provided all four combinations should be possible.
I have done like you have suggested and I get the same problem. Here is a screenshot of what I have done. Anything else that I can try?
- Example
- Example.PNG (26.25 KiB) Viewed 3249 times
Please recheck article "a4". It contains the combination horizontal/vertical instead of square/vertical
I have fixed that and I am still getting the same problem. If being able to select one option of the varient and nothing else. Any other suggestions that I might be able to try?
Maybe we misunderstood what you really need because it seems that variants of selection products are not what you are looking for. Can you please explain again what the frontend should display using a suitable example (maybe a drawing helps a lot)?
On the front end that user will be able to choose from any option from one selection menu and then move to the next selection menu and choose any selection from that one and etc.
