Typo3 - Categorie and Subcategorie
tenkraD
Post by tenkraD » 18 Jan 2018, 16:12
Salute everyone,
i'd like to have my products in sub categories of a categorie.
So i created under catalog the categorie and in it the subcategories.
Then i attached the products to the sub categorie.
> Categorie "kitchen" -> subcategorie "tables", and to tables i attached the products.
Is it possible, out of the box, to see all my products of the sub categories in "the catalog stage area" while im on the categorie?
I know i can attach the products twice in the backend to categorie and sub categorie and then its working but does it give an more elegant way to handle that?
I use typo3 7.6.x and aimeos 17.10.x
Many thanks
Re: Typo3 - Categorie and Subcategorie
Post by aimeos » 18 Jan 2018, 18:11
In the way you currently do it, you have the advantage that you have control over the product order in the listing.
The alternative is setting this option: https://aimeos.org/docs/Configuration/C ... sts/levels
It will aggregate all products from the sub-categories (up to the level you configure) into a combined product listing.
superscotty19
Post by superscotty19 » 08 Jun 2019, 01:12
I'm having this exact same issue. I've edited the T3 template > Setup field to include:
# Include products of sub-categories in the product list of the current category
plugin.tx_aimeos.settings.client.html.catalog.lists.levels = 1
... but nothing happens.
TYPO3 8.7
Aimeos 18.10.8
Aimeos_dist 18.4.0
Do I have the correct code/location?
-S.
Post by aimeos » 09 Jun 2019, 09:40
"1" is only from the given category, "2" adds products from direct child categories too and "3" adds products from all sub-categories. Please keep in mind that if you have the same products in different sub-categories at different positions, they will be shown several times. This is a behavior introduced by MySQL >= 5.7
superscotty19
Post by superscotty19 » 10 Jun 2019, 23:47
First of all, thank you for the detailed reply & explanation!
I can confirm it works (!) but I have a new issue: sub-sub-categories.
Preamble: Assume the following category structure:
  • Bikes
    • Road
      Mountain
      • Front Suspension
        Full Suspension
... and assume I only have 2 bikes in the "Front Suspension" sub-sub-category.
Using "1", I only see the bikes when I click "Front Suspension", as expected.
Using "2", I see the bikes when I click "Front", as well as "Mountain", as expected.
Using "3", I see the bikes when I click "Front", as well as "Mountain", as expected ... but I don't see them when I click "Bikes".
Just for fun, I tried entering a value of "4" and got:
ERROR: No catalog node for ID "16"
... So clearly there's a meaning behind the numbers.
Is it possible to have listing go an extra sub-category in depth, as above?
Thanks again,
-Scott.
superscotty19
Post by superscotty19 » 11 Jun 2019, 04:43
Update!
After I posted, I set the value back to "3". Well, it's been a few hours since I did that. I returned to my workstation and reloaded the page for fun ... and guess what?! It's working!!!
Now, in the other "images..." thread I have, I spoke of a potential cache issue ... could that be the case here? I also changed the directory permissions for /uploads/tx_aimeos from 775 to 755 ... but that shouldn't affect viewing?
This is weird, so I created a 2 new products - 1 without an image, 1 with - and both instantly worked (minus the image, but that's another thread). I guess it's not cache!
Thanks!
-S.
Post by aimeos » 11 Jun 2019, 07:32
The frontend output is cached until you clear the TYPO3 frontend cache or something else happens that clears caches (partitially) like saving a product in the admin interface. You can disable caching for development completely in the Aimeos configuration in the Extension Manager
