Get product category
Alex K
Post by Alex K » 02 Jun 2018, 14:16
Hi) I cant find any information how to get Categories list of Product. I checked default templates and documentation for class Item.. but failed. Please, can you show me right way?) I want to show product category to some products.
Re: Get product category
Post by aimeos » 02 Jun 2018, 20:46
Do you want to show the current category of the product or all product categories if the product is in several categories?
The categories are not retrieved by default for each product, so you have to create a decorator for the catalog lists HTML client that fetches the categories for the products shown: https://aimeos.org/docs/Developers/Html ... components
To get the categories use something like this:
$listManager = \Aimeos\MShop\Factory::createManager( $this->getContext(), 'catalog/lists' );
$search = $listManager->createSearch( true );
$expr = [
    $search->compare( '==', 'catalog.lists.refid', array_keys( $view->listProductItems ) ),
    $search->compare(  '==, 'catalog.lists.domain', 'product' ),
    $search->getConditions()
$search->setConditions( $search->combine( '&&', $expr ) );
$map = [];
foreach( $listManager->searchItems( $search ) as $listItem ) {
    $map[$listItem->getRefId()] = $listItem->getParentId();
$manager = \Aimeos\MShop\Factory::createManager( $this->getContext(), 'catalog' );
$search = $manager->createSearch( true );
$expr = [
    $search->compare( '==', 'catalog.id', $map ),
    $search->getConditions(),
$view->listListMap = $map;
$view->listCategories = $manager->searchItems( $search );
Alex K
Post by Alex K » 03 Jun 2018, 11:34
I need both) Thank you for help! I will try!
Alex K
Post by Alex K » 04 Jun 2018, 14:06
Thanks again for help! I finnaly got my categories for each product with help of decorator. I hope it's not forbiden, i'll give my result as example, if someone need it.
Thi is my Decorator for List, it's fast solution.
<?php
namespace Aimeos\Client\Html\Common\Decorator;
class CategoryListsDecorator
    extends \Aimeos\Client\Html\Common\Decorator\Base
    implements \Aimeos\Client\Html\Common\Decorator\Iface
	 * Adds the data to the view object required by the templates
	 * @param \Aimeos\MW\View\Iface $view The view object which generates the HTML output
	 * @param array &$tags Result array for the list of tags that are associated to the output
	 * @param string|null &$expire Result variable for the expiration date of the output (null for no expiry)
	 * @return \Aimeos\MW\View\Iface The view object with the data required by the templates
	 * @since 2018.01
	public function addData( \Aimeos\MW\View\Iface $view, array &$tags = array(), &$expire = null )
		$view = parent::addData( $view, $tags, $expire );
		if(count($view->get( 'listProductItems' )) > 0){
			$productsList = $view->get( 'listProductItems' );
			$productsList = $this->reachProducts($productsList);
			$view->listProductItems = $productsList;
		} else {
			$productsList = $view->get( 'promoItems' );
			$view->promoItems = $productsList;
		return $view;
	protected function reachProducts($productsList){
		foreach ($productsList as $id => $item) {
				$res = $this->getCategories($item);
				$productsList[$id]->listCategories = $res;
		return $productsList;
	protected function getCategories($product){
		$expr = [
		    $search->compare( '==', 'catalog.lists.refid', $product->getId() ),
		    $search->compare(  '==', 'catalog.lists.domain', 'product' ),
		$map = [];
		    $map[] = $listItem->getParentId();
		$expr = [
		return $manager->searchItems( $search );
Alex K
Post by Alex K » 04 Jun 2018, 14:12
And also simple decorator for detail product
<?php
class CategoryDetailDecorator
	 * @since 2018.01
		$expr = [
		    $search->compare( '==', 'catalog.lists.refid', $view->get( 'detailProductItem' )->getId() ),
		$map = [];
		$expr = [
		return $view;
Post by aimeos » 04 Jun 2018, 16:28
Your decorator for the list slows down your application because you fetch the categories for each product separately. Instead, you should retrieve all catalog<->product references and catalog items once and map them afterwards. This will be much faster.
sixbynine
Post by sixbynine » 19 Aug 2018, 15:54
I'm trying to create a new decorator. I had a few beginner questions and I find the answers by testing in the meantime :)
So it is solved !
I keep the post just in case it could help someone else !
Basically, my decorator was not working because I needed to clear the cache so aimeos can use the updated shop.php config file.
I read :
- https://aimeos.org/docs/Developers/Html ... components
- this post
I decided to make a few tests... I first tried to make one with the code available here (thank you Alex K!)
<?php
    * @since 2018.01
      } else {
      return $view;
      $expr = [
      $map = [];
      $expr = [
and I've a few simple questions :
Let's guess my decorator is called like this one CategoryListsDecorator
1. I added my decorator in my shop.php file :
'client' => [
      'html' => [
         'catalog' => [
          'lists' => [
            'decorators' => [
              'global' =>array('CategoryListsDecorator'),
Is this the correct way? YES
2. About the path of my decorator, I guess it is like the basket plugins : MyDecoratorName.php
So I add it in my ext folder :
/ext/myext/client/html/src/Client/Html/Common/Decorator/CategoryListsDecorator.php
Is this correct? YES
3. Mmmh... stupid question :roll: how do i finally get the new data in the list body view?
Could it be this way:
$listCategories = $this->get( 'myParam', [] );
YES but $this->myParam works too :)
As always, thank you very much for your patience !
sbn
mr.zherart
Post by mr.zherart » 25 Mar 2021, 07:36
Hi, Aimeos. I have the same question about getting the product category.
I am using shop "aimeos/aimeos-laravel": "~2020.10".
In our case:
1. product URL should have /{f_name}/{d_name} structure (so we need add f_name param everywhere in $view->url helper of product),
2. we restrict a product to have only one category,
3. sometimes, we need to fetch products by attribute and have a mix of products with different categories /{f_name}/{d_name} in the list.
I see answers on the forum about using catalog.lists.refid and, right now, I use trait with fetch all catalogs by product ids and set each related category to a product. However, it is tedious to set up decorators for all client/html wich work with products and set up product->category relation.
I want to ask. Maybe I can somehow use a decorator to extend mshop manager sql join and manager item for getting category with each product (I just need category URL segment), or add the catalog to mshop_product_list item for getting like product relation domain?
Thank you for your answer and the great framework!
Post by aimeos » 28 Mar 2021, 06:44
In 2020.x and later, things are much simpler now. The product manager can retrieve the categories attached to the products itself if you use:
$productManager->search( $productManager->filter(), ['catalog' => ['text']] );
This will add the categories including their texts to the product items. For the HTML frontend, you can also add them by configuration using:
client/html/catalog/domains => ['media', 'price', 'text', 'catalog' => ['text']]
mr.zherart
Post by mr.zherart » 31 Mar 2021, 13:35
Yes, it is working. Thank you.
But it is not obvious in documentation, moreover, for those who will read this, I will add that catalog (also as supplier, stock *) retrives via dot notation like $item->get('.catalog') and not by $item->getRefItem('catalog').
* I found this in vendor/aimeos/aimeos-core/lib/mshoplib/src/MShop/Product/Manager/Standard.php, but not tested, and maybe it wrong conclusion (about supplier and stock).
