Bug: Article Code(SKU) does not allow dots
hello aimeos
as soon as the article code contains a dot, the adaption of variants of a selection product is not possible. the dropdown of the variant information, title, sku, attributes etc. does not work.
would it be possible to fix this bug in a future version? all our article codes contain dots.
cheers
Volker
Version 18.4.1
cheers
Volker
Version 18.4.1
Re: Bug: Article Code(SKU) does not allow dots
Thank you for your bug report!
This has been fixed in dev-master and will be part of the next release (2018.07):
https://github.com/aimeos/ai-admin-jqad ... 1b80d4f475
thank you!
works well with 18.7.x
