Customer or customer group specific items
clearmedia
Post by clearmedia » 22 Aug 2018, 11:26
we use the "Customer or customer group specific items" extension, and we have a problem with them.
This extension has been tested for clean aimeos installations. We have not changed anything but only installed this extension.
At aimeos there are 20 products and 100 users.
Aimeos on arrival at eshop freezes and writes error: Allowed memory size of 1073741824 bytes exhausted (tried to allocate 20480 bytes)...
It is the following function getGroupIds() in:
ext/ai-customergroups/lib/custom/src/MShop/Common/Manager/Decorator/CustomerGroup.php
protected function checkItem( \Aimeos\MShop\Common\Item\ListRef\Iface $item, $date )
	$userId = $context->getUserId();
	$groupIds = $context->getGroupIds();
	$custIds = $cgroupdIds = [];
	foreach( $item->getListItems( 'customer', 'default' ) as $listItem )
		if( ( $listItem->getDateStart() === null || $listItem->getDateStart() < $date )
			&& ( $listItem->getDateEnd() === null || $listItem->getDateEnd() > $date )
			$custIds[] = $listItem->getRefId();
	foreach( $item->getListItems( 'customer/group', 'default' ) as $listItem )
			$cgroupdIds[] = $listItem->getRefId();
	if( ( !empty( $custIds ) || !empty( $cgroupdIds ) )
		&& ( empty( $custIds ) || !in_array( $userId, $custIds ) )
		&& ( empty( $cgroupdIds ) || array_intersect( $groupIds, $cgroupdIds ) === [] )
		return false;
	return true;
This function follows on:
vendor/aimeos/aimeos-laravel/src/Aimeos/Shop/Base/Context.php
protected function addGroups( \Aimeos\MShop\Context\Item\Iface $context )
	if( ( $userid = Auth::id() ) !== null )
		$context->setGroupIds( function() use ( $context, $userid )
			$manager = \Aimeos\MShop\Factory::createManager( $context, 'customer' );
			return $manager->getItem( $userid, array( 'customer/group' ) )->getGroups();
	return $context;
Did anyone have a similar problem? Or maybe somebody can not help? Pricing rules work if instead of this function we insert the empty array.
Can not anyone know how to extend vendor/aimeos/aimeos-laravel/src/Aimeos/Shop/Base/Context.php?
Thx
Re: Customer or customer group specific items
Post by aimeos » 24 Aug 2018, 14:07
Which Laravel and Aimeos version are you using?
There was an improvment in aimeos-laravel 2018.07 that reduces the number of queries for checking authentication so please give the latest 2018.07 version a try.
If that doesn't help, please ask for support from the Aimeos company where you've bought the extension.
clearmedia
Post by clearmedia » 25 Aug 2018, 14:33
We use the version 2018.07
My composer.json
    "name": "laravel/laravel",
    "description": "The Laravel Framework.",
    "keywords": ["framework", "laravel"],
    "license": "MIT",
    "type": "project",
    "require": {
        "php": ">=7.0.0",
        "aimeos/ai-admin-jqadm": "^2018.07",
        "aimeos/ai-admin-jsonadm": "^2018.07",
        "aimeos/ai-client-html": "^2018.07",
        "aimeos/ai-client-jsonapi": "^2018.07",
        "aimeos/ai-controller-frontend": "^2018.07",
        "aimeos/ai-controller-jobs": "^2018.07",
        "aimeos/ai-gettext": "^2018.07",
        "aimeos/ai-laravel": "^2018.07",
        "aimeos/ai-swiftmailer": "^2018.07",
        "aimeos/aimeos-core": "^2018.07",
        "aimeos/aimeos-laravel": "^2018.07",
        "aimeoscom/ai-customergroups": "^2018.04",
        "barryvdh/laravel-debugbar": "^3.1",
        "doctrine/dbal": "^2.5",
        "fideloper/proxy": "~3.3",
        "intervention/image": "^2.4",
        "laravel/framework": "5.5.*",
        "laravel/tinker": "~1.0",
        "league/flysystem-aws-s3-v3": "^1.0"
    "require-dev": {
        "filp/whoops": "~2.0",
        "fzaninotto/faker": "~1.4",
        "mockery/mockery": "~1.0",
        "phing/phing": "^2.16",
        "phpunit/phpunit": "~6.0",
        "symfony/thanks": "^1.0"
    "autoload": {
        "files": [
            "app/Helpers.php"
        "classmap": [
            "database/seeds",
            "database/factories"
        "psr-4": {
            "App\\": "app/"
    "autoload-dev": {
        "files": [
            "app/Helpers.php"
        "psr-4": {
            "Tests\\": "tests/"
    "extra": {
        "laravel": {
            "dont-discover": [
    "scripts": {
            "@php -r \"file_exists('.env') || copy('.env.example', '.env');\""
        "post-create-project-cmd": [
            "@php artisan key:generate"
        "post-autoload-dump": [
            "Illuminate\\Foundation\\ComposerScripts::postAutoloadDump",
            "@php artisan package:discover"
        "post-update-cmd": [
            "php artisan vendor:publish --tag=public --force",
            "php artisan migrate"
    "config": {
        "preferred-install": "dist",
        "sort-packages": true,
        "optimize-autoloader": true
    "repositories": [{
        "type": "composer",
        "url": "https://packages.aimeos.org/aimeoscom"
michal.fehér
Post by michal.fehér » 26 Aug 2018, 06:58
What do you mean contact Aimeos company? As far as I understand, it's an official extension - https://aimeos.com/extensions/.
Which company should we contact then?
nos3
Post by nos3 » 27 Aug 2018, 07:47
michal.fehér wrote:What do you mean contact Aimeos company? As far as I understand, it's an official extension - https://aimeos.com/extensions/.
Hi Michael
The Aimeos community can't support the proprietary extensions of the Aimeos company even if both share the same name. Sorry for the confusion.
Can you post the output of "composer show"?
Maybe there's also something wrong in the data but that's only a wild guess because locally we haven't noticed any problems. If you want to share sensitive information, you can contact me directly.
Cheers
Norbert
michal.fehér
Post by michal.fehér » 28 Aug 2018, 06:05
Thanks Norbert for the reply.
Yes I can understand the community cant support paid plugins, but I thought user with nickname "aimeos" and role "administrator" was Aimeos representative. If not, can you tell me what is the best way to contact Aimeos?
Thanks.
clearmedia
Post by clearmedia » 28 Aug 2018, 06:16
Thanks Norbert for the reply. I'm sending you output for composer show.
aimeos/ai-admin-jqadm                 2018.07.9  Aimeos ai-admin-jqadm exte...
aimeos/ai-admin-jsonadm               2018.07.3  Aimeos ai-admin-jsonadm ex...
aimeos/ai-client-html                 2018.07.10 Aimeos ai-client-html exte...
aimeos/ai-client-jsonapi              2018.07.4  Aimeos JSON API extension
aimeos/ai-controller-frontend         2018.07.5  Aimeos ai-controller-front...
aimeos/ai-controller-jobs             2018.07.8  Aimeos ai-controller-jobs ...
aimeos/ai-gettext                     2018.07.2  Aimeos Gettext extension
aimeos/ai-laravel                     2018.07.3  Laravel adapter for Aimeos...
aimeos/ai-swiftmailer                 2018.07.1  SwiftMailer adapter for Ai...
aimeos/aimeos-core                    2018.07.17 Full-featured e-commerce c...
aimeos/aimeos-laravel                 2018.07.3  Full-featured Laravel web ...
aimeoscom/ai-customergroups           2018.07.6  Aimeos ai-customergroups e...
aws/aws-sdk-php                       3.67.0     AWS SDK for PHP - Use Amaz...
barryvdh/laravel-debugbar             v3.1.5     PHP Debugbar integration f...
composer/installers                   v1.5.0     A multi-framework Composer...
dnoegel/php-xdg-base-dir              0.1        implementation of xdg base...
doctrine/cache                        v1.8.0     Caching library offering a...
doctrine/dbal                         v2.8.0     Database Abstraction Layer
doctrine/event-manager                v1.0.0     Doctrine Event Manager com...
doctrine/inflector                    v1.3.0     Common String Manipulation...
doctrine/instantiator                 1.1.0      A small, lightweight utili...
doctrine/lexer                        v1.0.1     Base library for a lexer t...
egulias/email-validator               2.1.5      A library for validating e...
erusev/parsedown                      1.7.1      Parser for Markdown.
fideloper/proxy                       3.3.4      Set trusted proxies for La...
filp/whoops                           2.2.0      php error handling for coo...
fzaninotto/faker                      v1.8.0     Faker is a PHP library tha...
guzzlehttp/guzzle                     6.3.3      Guzzle is a PHP HTTP clien...
guzzlehttp/promises                   v1.3.1     Guzzle promises library
guzzlehttp/psr7                       1.4.2      PSR-7 message implementati...
hamcrest/hamcrest-php                 v2.0.0     This is the PHP port of Ha...
intervention/image                    2.4.2      Image handling and manipul...
jakub-onderka/php-console-color       0.1
jakub-onderka/php-console-highlighter v0.3.2
laravel/framework                     v5.5.42    The Laravel Framework.
laravel/tinker                        v1.0.7     Powerful REPL for the Lara...
league/flysystem                      1.0.46     Filesystem abstraction: Ma...
league/flysystem-aws-s3-v3            1.0.19     Flysystem adapter for the ...
maximebf/debugbar                     v1.15.0    Debug bar in the browser f...
mockery/mockery                       1.1.0      Mockery is a simple yet fl...
monolog/monolog                       1.23.0     Sends your logs to files, ...
mtdowling/cron-expression             v1.2.1     CRON for PHP: Calculate th...
mtdowling/jmespath.php                2.4.0      Declaratively specify how ...
myclabs/deep-copy                     1.8.1      Create deep copies (clones...
nesbot/carbon                         1.33.0     A simple API extension for...
nikic/php-parser                      v4.0.3     A PHP parser written in PHP
paragonie/random_compat               v9.99.99   PHP 5.x polyfill for rando...
phar-io/manifest                      1.0.1      Component for reading phar...
phar-io/version                       1.0.1      Library for handling versi...
phing/phing                           2.16.1     PHing Is Not GNU make; it'...
phpdocumentor/reflection-common       1.0.1      Common reflection classes ...
phpdocumentor/reflection-docblock     4.3.0      With this component, a lib...
phpdocumentor/type-resolver           0.4.0
phpspec/prophecy                      1.8.0      Highly opinionated mocking...
phpunit/php-code-coverage             5.3.2      Library that provides coll...
phpunit/php-file-iterator             1.4.5      FilterIterator implementat...
phpunit/php-text-template             1.2.1      Simple template engine.
phpunit/php-timer                     1.0.9      Utility class for timing
phpunit/php-token-stream              2.0.2      Wrapper around PHP's token...
phpunit/phpunit                       6.5.12     The PHP Unit Testing frame...
phpunit/phpunit-mock-objects          5.0.10     Mock Object library for PH...
psr/container                         1.0.0      Common Container Interface...
psr/http-message                      1.0.1      Common interface for HTTP ...
psr/log                               1.0.2      Common interface for loggi...
psr/simple-cache                      1.0.1      Common interfaces for simp...
psy/psysh                             v0.9.7     An interactive shell for m...
ramsey/uuid                           3.8.0      Formerly rhumsaa/uuid. A P...
sebastian/code-unit-reverse-lookup    1.0.1      Looks up which function or...
sebastian/comparator                  2.1.3      Provides the functionality...
sebastian/diff                        2.0.1      Diff implementation
sebastian/environment                 3.1.0      Provides functionality to ...
sebastian/exporter                    3.1.0      Provides the functionality...
sebastian/global-state                2.0.0      Snapshotting of global state
sebastian/object-enumerator           3.0.3      Traverses array structures...
sebastian/object-reflector            1.1.1      Allows reflection of objec...
sebastian/recursion-context           3.0.0      Provides functionality to ...
sebastian/resource-operations         1.0.0      Provides a list of PHP bui...
sebastian/version                     2.0.1      Library that helps with ma...
swiftmailer/swiftmailer               v6.1.2     Swiftmailer, free feature-...
symfony/console                       v3.4.14    Symfony Console Component
symfony/css-selector                  v4.1.3     Symfony CssSelector Component
symfony/debug                         v3.4.14    Symfony Debug Component
symfony/event-dispatcher              v4.1.3     Symfony EventDispatcher Co...
symfony/finder                        v3.4.14    Symfony Finder Component
symfony/http-foundation               v3.4.14    Symfony HttpFoundation Com...
symfony/http-kernel                   v3.4.14    Symfony HttpKernel Component
symfony/polyfill-ctype                v1.9.0     Symfony polyfill for ctype...
symfony/polyfill-mbstring             v1.9.0     Symfony polyfill for the M...
symfony/polyfill-php70                v1.9.0     Symfony polyfill backporti...
symfony/process                       v3.4.14    Symfony Process Component
symfony/psr-http-message-bridge       v1.0.2     PSR HTTP message bridge
symfony/routing                       v3.4.14    Symfony Routing Component
symfony/thanks                        v1.1.0     Give thanks (in the form o...
symfony/translation                   v4.1.3     Symfony Translation Component
symfony/var-dumper                    v3.4.14    Symfony mechanism for expl...
symfony/yaml                          v4.1.3     Symfony Yaml Component
theseer/tokenizer                     1.1.0      A small library for conver...
tijsverkoyen/css-to-inline-styles     2.2.1      CssToInlineStyles is a cla...
vlucas/phpdotenv                      v2.5.1     Loads environment variable...
webmozart/assert                      1.3.0      Assertions to validate met...
zendframework/zend-diactoros          1.8.5      PSR HTTP Message implement...
nos3
Post by nos3 » 28 Aug 2018, 14:18
Your package setup seems to be OK. Can you add a debug statement to find out how often checkItem() is called?
Another thing to check: Is there a circular reference in your data, e.g. customer item refers to the same customer item via the list table or something like
1. customer -> 2. customer -> 1. customer
@Michal: Use the Aimeos.com contact form, there you can get in touch with us directly:
https://aimeos.com/aimeos-gmbh/contact/
michal.fehér
Post by michal.fehér » 03 Sep 2018, 15:07
Hi Norbert,
the only way how to make the extension work is to make this change:
//		$groupIds = $context->getGroupIds();
		$groupIds = (DB::table('users_list')->select('refid')->where('typeid', 3)->where('parentid', $userId)->get()->pluck('refid')->toArray());
in
The original getGroupIds method has infinite loop or something. This was tested on fresh install of laravel so it shouldnt be anything you mentioned before.
Another strange thing that we noticed. When I restrict user from seeing all products in category (166 products in total) but one, the pagination wont work as expected. I would still see 4 pages available when there shouldnt be none (as there is only 1 product to see).
I checked the code (CustomerGroup Decorator) and I noticed you first mage all the queries to determine totals (listProductTotal, listPageSize) and only after that you unset array of items with checkItem method (check the attached screenshot).
Can you please advise how should we fix this?
Thanks.
nos3 wrote:Your package setup seems to be OK. Can you add a debug statement to find out how often checkItem() is called?
nos3
Post by nos3 » 05 Sep 2018, 09:45
Regarding the infinitive loop, can you post a dump of your users, users_list and mshop_customer_group tables (structure and data) nevertheless? Because we are unable to reproduce the problem.
