Aimeos Orders - Revised Orders!
mohal_04
Post by mohal_04 » 31 Aug 2018, 06:34
Laravel: 5.6
Aimeos: 2018.04
PHP: 7.1.18
So the old system has a functionality for revised orders. Where a customer may ask to revise her order and system was handling it as the same order with a revision number.
Is there anything similar in Aimeos?
Please, reply ASAP!
Thanks!
Re: Aimeos Orders - Revised Orders!
Post by aimeos » 01 Sep 2018, 13:37
No, you can't change orders after they are being placed for various reasons but it's easy to copy them and add the old order ID as related ID in the mshop_order table.
mohal_04
Post by mohal_04 » 07 Nov 2018, 05:08
aimeos wrote:No, you can't change orders after they are being placed for various reasons but it's easy to copy them and add the old order ID as related ID in the mshop_order table.
Thanks for your reply! So, how do we manage returned orders?
Thanks!
