Aimeos - Reports Section
mohal_04
Post by mohal_04 » 28 Sep 2018, 12:36
Laravel: 5.6
Aimeos: 2018.04
PHP: 7.1.18
I don't see a Reports section in Aimeos. I can see different kind of graphs on Dashboard but I don't see a separate Reports Section in Administration panel.
Where I can see all reports?
Thanks!
Re: Aimeos - Reports Section
Post by aimeos » 28 Sep 2018, 17:45
What kind of reports do you mean?
mohal_04
Post by mohal_04 » 01 Oct 2018, 14:01
aimeos wrote:What kind of reports do you mean?
Similar kind of reports and graphs that I see on dashboard. For example, last 30 days payments, total orders from the beginning, total deductions, etc.
Thanks!
Post by aimeos » 02 Oct 2018, 07:49
You have the latest orders and graphs in the dashboard and you can export orders in CSV format in the order panel. If you need more reports/graphs, you can implement them by adding new subparts to the dashboard:
https://github.com/aimeos/ai-admin-jqad ... /Dashboard
