Aimeos Orders - Manual Order Entry
mohal_04
Post by mohal_04 » 05 Oct 2018, 12:40
Laravel: 5.6
Aimeos: 2018.07
PHP: 7.1.18
So, I have been trying to figure out how I can enter an order manually? I can see a complete list of orders in the administration panel but I don't see any button there to add an order manually.
So, does Aimeos facilitates this kind of functionality?
Please, reply ASAP!
Thanks!
Re: Aimeos Orders - Manual Order Entry
Post by aimeos » 07 Oct 2018, 07:16
Creating new orders in the Aimeos backend is currently not implemented and you should use the frontend instead.
FedericoCánovas
Post by FedericoCánovas » 08 Oct 2018, 11:52
We need this feature too
mohal_04
Post by mohal_04 » 08 Oct 2018, 13:47
aimeos wrote:Creating new orders in the Aimeos backend is currently not implemented and you should use the frontend instead.
OK!
So, I was searching Packagist for any Aimeos extension related to Manual Order Entry. And I found 3-4 extensions... you can check them at the following link:
https://packagist.org/packages/aimeos/a ... al%20order
So, should I try any of them? Is it safe to use any 3rd party extension?
Thanks!
mohal_04
Post by mohal_04 » 09 Oct 2018, 17:19
OK!
Thanks!
Sorry, I misunderstood it! It is not for Aimeos.
Thanks!
Post by aimeos » 10 Oct 2018, 17:51
Implementing that feature is a bit difficult but if all can join forces and to help get this done, we would appreciate that very much! :-)
mohal_04
Post by mohal_04 » 11 Oct 2018, 10:50
aimeos wrote:Implementing that feature is a bit difficult but if all can join forces and to help get this done, we would appreciate that very much! :-)
Hey, count me in. I would love to be part of something this much amazing. :)
Post by aimeos » 12 Oct 2018, 20:57
To get the same functionality in the checkout as in the frontend, I think we need to use the JSON API API for implementing that feature. Otherwise, it would be hard to get e.g. limiting the payment/delivery options based on the basket content.
liviu
Post by liviu » 22 May 2020, 14:07
any update on this feature? Was it implemented?
