Different Configuration options for backend?
tenkraD
Post by tenkraD » 30 Jan 2019, 17:15
Hello again,
is it possible to set different configuration options in backend depending on the selected site?
Im trying to set an different manager for the categories on one locale site.
I can change the manager in backend gobally with ts:
module.tx_aimeos.settings.mshop.categorie.manager.name = someothermanager
but i want this setting just for 1 locale site in the backend.
Thanks for response
Re: Different Configuration options for backend?
Post by aimeos » 31 Jan 2019, 13:13
No, it's only all or nothing for the backend (module.tx_aimeos...) or the frontend (plugin.tx_aimeos...).
You can add arbitrary configuration in the locale-site item in the backend and use that configuration to check if some other code should be exectued in your manager.
