PHP Runtime Deprecation Notice TYPO3 v9.5.5
DigitalGizmo
Post by DigitalGizmo » 17 Apr 2019, 20:21
I've installed Aimeos via composer to my TYPO3 (version 9.5.5 with PHP version 7.2.17, OS is FreeBSD 11.2-RELEASE-p8 OS and the webserver is an Apache/2.4 ) site. And when I try to open the Aimeos (version 19.1.0) module in the backend, I'm getting the following Error Message:
Core: Exception handler (WEB): Uncaught TYPO3 Exception: #1476107295: PHP Runtime Deprecation Notice: Non-static method TYPO3\CMS\Core\Crypto\PasswordHashing\PasswordHashFactory::getDefaultHashInstance() should not be called statically in /TYPO3ROOTPATH/public/typo3conf/ext/aimeos/Classes/Base/Context.php line 146 | TYPO3\CMS\Core\Error\Exception thrown in file /TYPO3ROOTPATH/public/typo3/sysext/core/Classes/Error/ErrorHandler.php in line 116. Requested URL: https://websiteurl/typo3/index.php?route=%%2Fweb%%2FAimeosTxAimeosAdmin%%2F&token=--AnonymizedToken--
Is this somesort of an compatibility issue between Aimeos and TYPO3. Or has my PHP configuration an error?
Thank you for your answers
Re: PHP Runtime Deprecation Notice TYPO3 v9.5.5
Post by aimeos » 19 Apr 2019, 16:23
If you are using Aimeos 18.10, please make sure you've installed the latest one (18.10.8).
DigitalGizmo
Post by DigitalGizmo » 24 Apr 2019, 05:57
I've reinstalled TYPO3 and now it works. Thanks for your reply.
