JS-Error on Aimeos Catalog Search Plugin
Hello Admin,
I use the catalog search Plugin instead of the catalog Filter Plugin, but i saw it generates an JS-Error when usign this Plugin.
Error in Google Chrome: "Uncaught SyntaxError: Unexpected token < "
And in Internet Explorer: " SCRIPT1002: SCRIPT1002: Syntax error"
I found out that The catalog search Plugin loads a JS Script in the <head> which has html in it and this leads to the error.
If i use now the catalog Filter Plugin it loads a JS Script in the <head> which has JS-Code in it for the Filter and generates no Error
I think in the script src for the catalog search plugin the counts is missing.
Will this be fixed soon?
Thank you very much.
Aimeos 18.10.7 / Typo3 8.7.24
<script type="text/javascript" defer="defer" src="/website/localesite/?type=191351524"></script>
<script type="text/javascript" defer="defer" src="/website/localesite/counts/?type=191351524"></script>
Re: JS-Error on Aimeos Catalog Search Plugin
Did you forget to configure the page for the suggestions in the flexform?
No i didnt forget that.
But i saw now under catalog search it has no options to select counts page.
Under catalog filter plugin the counts page can be selected.
Maybe this is missing under catalog search plugin?
- catalog search plugin options.JPG (44.47 KiB) Viewed 1753 times
- catalog filter plugin options.JPG (38.79 KiB) Viewed 1753 times
OMG, found now a little dirty fix.
Change the catalog search plugin to catalog filter, insert the counts page, save the page in typo3.
Clear frontend and backend cache. View page, no error.
Change the catalog filter plugin back to catalog search, save the page and clear the caches - no errors anymore.
The script src tag is now displayed with the missing counts part.
Better solution: Set this in the TSConfig field of your Catalog Search plugin:
We've added a check so this won't be neccessary in new versions.
client.html.catalog.count.enable = 0
