How can i override controller and his method by my extantion
kishanbupadhyaya
Post by kishanbupadhyaya » 24 Jun 2019, 13:57
Hi aimeos,
Basically i am creating my own extantion. i have followed following this link.
https://aimeos.org/docs/Developers/Create_an_extension
And i got result for only views but i want to override your controllers, method, Classes e.t.c but i am not getting result. it execute all logic from ai-client-html but i want to execute from my extention.
Please kindly help me and Thank you in advance.
Best Regaurds,
Kishan Upadhyay
Re: How can i override controller and his method by my extan
Post by aimeos » 24 Jun 2019, 17:33
Create a class with another name (namespace is the same as the existing class you want to overwrite), extend from the existing class and overwrite the methods you need. Then, configure the name of your new class e.g. for the catalog lists component: https://aimeos.org/docs/Configuration/C ... lists/name
You can also dynamically extend classes with decorators to add additional data for example:
https://aimeos.org/docs/Developers/Html ... components
kishanbupadhyaya
Post by kishanbupadhyaya » 25 Jun 2019, 06:01
Thank you for replay aimeos and i have try as per your instruction and it worked.
One last thing that how you get data from database. i want to learn that how can i get data from database and make my own thing as per requirement. and thank you in advance.
Best Regards,
Kishan Upadhyay
Post by aimeos » 25 Jun 2019, 15:54
Use the Aimeos frontend controllers to get the data you need:
https://github.com/aimeos/ai-controller ... r/Frontend
kishanbupadhyaya
Post by kishanbupadhyaya » 26 Jun 2019, 05:13
Thank you aimeos for your support. Is there any config settings remains for this i apply frontend controllers in my extension but yet he executes from ai-controller-frontend.
Best Regards,
Kishan Upadhyay
Post by aimeos » 26 Jun 2019, 10:35
Like all other classes you want to overwrite in Aimeos, you have to give yours a new name and configure that name e.g. for the product controller:
https://aimeos.org/docs/Configuration/C ... oduct/name
kishanbupadhyaya
Post by kishanbupadhyaya » 26 Jun 2019, 11:59
Hi Aimeos after following your step from documentation i getting this error. If you help me on this.
Best Regards,
Kishan Upadhyay
Final Error i get is this.
see this class that i have made and name of file are alos same
Shop.php file
Shop.php file
Post by aimeos » 27 Jun 2019, 09:07
Please make sure you are using the right interface for your installed version. Currently, you've installed Aimeos 2018.10 which uses this interface: https://github.com/aimeos/ai-controller ... ce.php#L78
But your class implements the newer 2019.04 interface: https://github.com/aimeos/ai-controller ... /Iface.php
The frontend controller interfaces have been rewritten in 2019.x to be much more intuitive and easier to use. If you want to implement your own frontend controllers, you should use Aimeos 2019.04+
unknow76616
Re: How can i override controller and his method by my extantion
Post by unknow76616 » 02 Nov 2023, 10:58
@aimoes
all links is outdated , Please how i can overwrite aimeos-laravel/src/Controller/CheckoutController.php in my Extension?
