Variant Prices Not Displaying
Hi again,
TYPO3 8.7
Aimeos 18.10
I've created a Selection Product and variants inside it.
I edit the variant in its respective Article view and go to the Prices tab, where I set a price for the variant article
In the front end, the price field is blank, no matter which variant I choose from the dropdown
Screenshot attached, please advise - thanks as always,
-Scott.
TYPO3 8.7
Aimeos 18.10
-Scott.
- Screenshot_2019-06-25 Detail.png (99.87 KiB) Viewed 2897 times
Re: Variant Prices Not Displaying
Please make sure the used currency is the one that's used in the first locale item, the prices are enabled and the minimum quantity is 1
Yup,
Had all those checked before I wrote - see screenshot.
-S.
-S.
- Screenshot_2019-06-26 Dutch Cycle Lightning [TYPO3 CMS 8 7 4].png (20.43 KiB) Viewed 2887 times
Can you post a screenshot of the Locale -> Locale panel?
Are prices shown in the list view?
Locale:
- Screenshot_2019-06-27 Dutch Cycle Lightning [TYPO3 CMS 8 7 4].png (5.11 KiB) Viewed 2881 times
I'm not sure which List VIew you're speaking of. The "Products" tab only shows the default columns: ID, Status, Type, Code, Label.
... but now I have a new problem. I can't view the Detail page! I get this error:
Oops, an error occurred! Code: 2019062710115568729ee6
-S.
-S.
That's the TYPO3 error log number and you need to look into ./typo3temp/var/log/* to see the error behind.
Thanks! Log indicated it was that stupid bootstrap package AGAIN causing havok. I had to upgrade it (or so I thought) in order to get another CE to display. In doing so, they changed all the layouts (they removed the "Default" preface) and the Detail page was expecting that layout.
Anyway, I'm happy to report that this issue is SOLVED! The problem was the locales. CAD was in position 1 instead of 0 - I changed it an I now have variant prices!
Thank you YET AGAIN!!!!
-S.
-S.
