Aimeos Setup Task replace
tenkraD
Post by tenkraD » 23 Jul 2019, 13:02
Hy all,
i wrote my own locale manager and item.
This manager i want to use in his setup task.
So question is how can i replace existing
ext\aimeos\Resources\Libraries\aimeos\aimeos-core\lib\mshoplib\setup\MShopAddLocaleData.php
with my own implementation?
Is this possible over configuration or in manifest file of my extension?
Many thanks tenkraD
Re: Aimeos Setup Task replace
Post by aimeos » 23 Jul 2019, 21:22
Sorry, setup tasks are the only classes you can't overwrite in Aimeos :-/
Maybe it would be a solution if you can add a replaces() method and the setup process removes the task name that is returned by the method?
