AIMEOS doesn't work
AIMEOS doesn't work
Hello
I have the following problem. If I click on "products" or wanna see something else then the site just reload. So nothing happens when I'm clicking on it.
Does anyone have the same issue or can help me please?
Thank you!
Thank you!
- 69002793_662444260928863_7043769236140851200_n.png (50.44 KiB) Viewed 1074 times
Re: AIMEOS doesn't work
Maybe your web server doesn't serve the CSS and JS files. Please have a look at the browser console (Network tab) to find out what's happening.
I downloaded the package. Now It works ^^
nevertheless thank you ^^
