Problems with loading images on frontend
First trial with aimeos in typo3. We added 12 images (very light once) but it is only loading the first 6 in front end. The others just show the loading wheel.
One more information: when I inspect the page - all products are displayed right away. After closing the inspection window and refreshing the browser (chrome) the problem remains the same!
Re: Problems with loading images on frontend
Which Aimeos and TYPO3 version are you using?
Typo3 is 9.5.9 / Aimeos - I cannot find any info in CMS about Version. We installed the newest about 1 week ago.
You can see the Aimeos version in the extension manager. Latest one is 19.7.3 which fixed a problem with Chrome lazy loading.
Hi
We had version 19.7.2 and updated to 19.7.3
now with 19.7.3 it is even worse - it is not loading any product
Do you have any errors in the browser console?
Remember that images are still lazy loaded by Javascript and you need to use the appropriate aimeos.js file from the Aimeos package.
here the info of my programmer.......
Yes,there is console error TypeError: $(...).datepicker is not a function[Learn More] in aimeos.js
We are using js from the aimeos package
Seems like you've removed the jquery-ui Javascript library which is necessary
No the jquery-ui Javacript is NOT removed
see attchment.
see attchment.
see attachment
- Unbenannt.JPG (37.4 KiB) Viewed 3403 times
