Setup db error
kuoyehs
Setup db error
Post by kuoyehs » 16 Oct 2019, 09:37
My project install aimeos package, and database use postgresSQL.
"aimeos/aimeos-laravel": "2019.07.x-dev",
"aimeos/ai-filesystem": "2019.07.x-dev",
"aimeos/ai-payments": "2019.07.x-dev",
"aimeos/ai-client-html": "2019.07.x-dev",
"aimeos/aimeos-core": "2019.07.x-dev"
I use two database to let aimeos and my project old users table merge.
'resource' => [
	'db' => [
            'adapter' => env('DB_CONNECTION', 'pgsql'),
            'host' => env('DB_HOST', '127.0.0.1'),
            'port' => env('DB_PORT', '5432'),
            'socket' => '',
            'database' => env('DB_DATABASE_SHOP', 'forge'),
            'username' => env('DB_USERNAME', 'forge'),
            'password' => env('DB_PASSWORD', ''),
            'stmt' => [],
            'limit' => 3, // maximum number of concurrent database connections
            'defaultTableOptions' => [
                'charset' => 'utf8',
                'collate' => '',
        'db-customer' => [
            'socket' => '',
            'database' => env('DB_DATABASE', 'forge'),
            'stmt' => [],
                'collate' => '',
When I run "php artisan aimeos:setup --option=setup/default/demo:1", and have the error message.
Re: Setup db error
Post by aimeos » 17 Oct 2019, 07:38
The database defined in your "db-customer" connection seems to contain your existing and modified "users" table and DBAL tries to remove an index what doesn't exist in the schema definition for "users". Please create an additional schema for "users" in your own Aimeos extension and add that index and the contstraint there so DBAL won't try to remove them any more:
https://aimeos.org/docs/Developers/Libr ... ing_tables
kuoyehs
Re: Setup db error
Post by kuoyehs » 17 Oct 2019, 10:30
I try to add code in ai-laravel extension lib/custom/setup/default/schema/customer.php, but still have error.
'exlcude' => array(
	'unq_api_token',
or
'exlcude' => array(
	'api_token',
or
'exlcude' => array(
	'unq_lvusr_api_token',
or
'exlcude' => array(
	'users_api_token_unique',
Re: Setup db error
Post by aimeos » 19 Oct 2019, 17:22
Try "exclude", not "exlcude"
kuoyehs
Re: Setup db error
Post by kuoyehs » 21 Oct 2019, 02:27
Your document is 'exlcude'.
Re: Setup db error
Post by aimeos » 21 Oct 2019, 06:45
That was a spelling error which has been corrected now. Thanks for mentioning!
