Error after aimeos update to 2019.10.* ,aimeos setup db error
awaidqureshi
Post by awaidqureshi » 10 Jan 2020, 13:27
I have upgraded my system from aimeos 2018.10.* to 2019.0.*
when i run aimeos:setup command there is an error
how can i solve this
Integrity constraint violation: 1452 Cannot add or update a child row: a foreign key constraint fails ("nordicforms_test"."#sql-50b_6086", CONSTRAINT "fk_mspropr_pid" FOREIGN KEY ("parentid") REFERENCES "mshop_product" ("id") ON DELETE CASCADE ON UPDATE CASCADE): ALTER TABLE mshop_product_property ADD CONSTRAINT fk_mspropr_pid FOREIGN KEY (parentid) REFERENCES mshop_product (id) ON UPDATE CASCADE ON DELETE CASCADE
Re: Error after aimeos update to 2019.10.* ,aimeos setup db error
Post by aimeos » 10 Jan 2020, 13:31
Did you have no foreign key constraint between mshop_product and mshop_product_property tables before?
Check, if there are records in mshop_product_property with a parentid value that isn't available in mshop_product any more.
