Want To Change Category Url
awaidqureshi
Post by awaidqureshi » 14 Jan 2020, 14:36
Default category url is http://......com/catgegoryname~categoryid
want to change it to only category name means
Please guide how can i do that
Re: Want To Change Category Url
Post by aimeos » 14 Jan 2020, 15:02
That will be difficult because the category name must be unique then and this is only rarely the case. Furthermore, things get more complicated if category names should translated into several languages.
For products, we've added a resolve() method to the product frontend controller that is used in the HTML client and which finds the product by its name:
https://github.com/aimeos/ai-controller ... #L294-L310
awaidqureshi
Post by awaidqureshi » 20 Jan 2020, 10:18
aimeos wrote: 14 Jan 2020, 15:02 That will be difficult because the category name must be unique then and this is only rarely the case. Furthermore, things get more complicated if category names should translated into several languages.
Can i replace this "~" with forward slash if yes then where i have to do the changes
Post by aimeos » 21 Jan 2020, 09:49
Only if you change the product detail routes too because they already use a "/" for separating name and id and/or pos. Otherwise, the Laravel router won't be able to distingish which route to use.
You can add a prefix like /category_name/c/123 to make routes unique.
ttyy
Post by ttyy » 09 Apr 2021, 13:19
Is is possible to create a custom route for instance /mytestpage/{f_catid} for category view? If so how I would disable required f_name param?
I've tried a similar approach, created a router but w/o f_name i'm getting an error handling the request
Error --
Illuminate\Routing\Exceptions\UrlGenerationException
Missing required parameter for [Route: aimeos_shop_tree] [URI: shop/{f_name}~{f_catid}] [Missing parameter: f_name].
URL: http://localhost:8000/category/2
Route: Route::get('category/{f_catid}/{f_name?}', '\Aimeos\Shop\Controller\CatalogController@treeAction');
Also same results with route: 'category/{f_catid}'
Post by aimeos » 11 Apr 2021, 12:08
You can overwrite existing Laravel routes by their name in ./routes/web.php, e.g.:
Route::match( array( 'GET', 'POST' ), 'mytestpage/{f_catid}', array(
	'as' => 'aimeos_shop_tree',
	'uses' => 'Aimeos\Shop\Controller\CatalogController@treeAction'
) )->where( ['site' => '[a-z0-9\.\-]+' );
Because the f_name parameter is added when the URL is generated in the template, it will be part of the URL as
/mytestpage/123?f_name=test
ttyy
Post by ttyy » 14 Apr 2021, 11:47
Thanks, adding name for the route did the trick!
