Input Type Checkbox no Value & no name submitted
tenkraD
Post by tenkraD » 16 Jan 2020, 18:58
I've made an Form with an Checkbox Input Field.
The Field name and the value will not be submitted with input type="checkbox"
<div class="input-group checkbox-new">
 <input type="checkbox" class="form-control-checkbox-code"
   name="<?= $enc->attr( $this->formparam( 'testname' ) ); ?>"
   value="<?= $enc->attr( 'testvalue' ); ?>"
</div>
If i change the type to input or something else it works. Is this a bug?
Thanks and good evening tenkraD
Re: Input Type Checkbox no Value & no name submitted
Post by aimeos » 17 Jan 2020, 11:17
The value is only submitted to the server if the checkbox is really checked. That's pure HTML and not related to Aimeos
