changing config files in ext
MSchrading
Post by MSchrading » 17 Jan 2020, 10:15
Hi aimeos
I've read the doc for this but can't come through.
Could you please give me an example to get this configuration changed in my symfony 4.3 application
(LAMP php 7.2) for this i.g.:
ext/ai-admin-jqadm/config/admin/jqadm.php
I put a changed one into:
ext/<myproject>/admin/jqadm/config/admin/jqadm.php
but nothing changed!
And how to put this in composer classmap so that all files in <myproject> folder will be included in autoloader?
please for a help
Michael
Re: changing config files in ext
Post by aimeos » 18 Jan 2020, 08:24
Please add your configuration to ./ext/<myproject>/config/admin.php and use
return [
    'jqadm' => [
MSchrading
Post by MSchrading » 20 Jan 2020, 08:22
Please give me this help:
Is the path relativ? And from where "./ext/<myproject>/..." and to which folder and do all other folder below belong to this directive?
i.e.: I have this file: ./ext/ai-admin-jqadm/config/admin/jqadm.php
which I have copied into:
./ext/<myproject>/admin/jqadm/config/admin/jqadm.php
How should this looks like in our ext/<myproject>/config/admin.php file?
Thank you
Post by aimeos » 21 Jan 2020, 09:35
Configuration options like "admin/jqadm/attribute/standard/subparts" directly match directories, files and array keys, e.g. in ./config/ (which is the configured base directory in the manifest.php file where the configuration options are relative to):
- file admin.php -> "admin" part
- ['jqadm' => ['attribute' => ['standard' => ['subparts' => ...]]]] -> rest of the configuration option parts
You shouldn't copy complete configuration files but only overwrite the options you need instead. The structure of the original file and your own file is the same.
