google merchant center - export from aimeos
einmaku
Post by einmaku » 23 Jan 2020, 16:13
I want to export all product data to a excel or CSV list. The goal is to use this sheet for uploading it to Google merchant center (google shopping campaigns).
I do not find any export function
Thanks for help
Re: google merchant center - export from aimeos
Post by aimeos » 24 Jan 2020, 09:36
There's only a XML export for products (and all other data) available. You can implement an CSV export yourself like the CSV export for orders:
https://github.com/aimeos/ai-controller ... Export/Csv
We would love to get a pull request on Github with your implementation from you :-)
einmaku
Post by einmaku » 27 Jan 2020, 11:12
I am looking for an aimeos pro who can integrate the export functionality into our typo3. You have any recommandations to find? ...... or anybody here who likes to do this job for us?
Thanks for reply.
Post by aimeos » 27 Jan 2020, 11:19
Ask the guys from the Aimeos company, they do custom implementations:
https://aimeos.com/aimeos-gmbh/contact
einmaku
Post by einmaku » 29 Jan 2020, 13:36
You wrote:
"There's only a XML export for products (and all other data) available. "
Where can I get the coding for XML export?
Post by aimeos » 29 Jan 2020, 18:46
prosatya
Post by prosatya » 05 Feb 2020, 09:52
Under TYpo3 Aimeos Where Avaiable ? XML export for products (and all other data) available
https://github.com/aimeos/ai-controller-jobs/
Is this code compatible for Typo 3 Extension aimeos with jobs.
If not how can i Extend aimeos and implement ai-controller-jobs under Typo 3 Extension aimeos.
Just give me some idea so i can start extend or integrate with Typo 3 Extension aimeos.
it will be great if any Documentation guide available.
Post by aimeos » 06 Feb 2020, 08:25
The ai-controller-jobs package is available in all integrations and also in the TYPO3 extension. It's available in ./typo3conf/ext/aimeos/Resource/Private/Extensions/.
Here's the documentation how you can implement a new job controller:
https://aimeos.org/docs/Developers/Cont ... controller
The existing job controllers are available here:
https://github.com/aimeos/ai-controller ... oller/Jobs
prosatya
Post by prosatya » 07 Feb 2020, 06:25
Thank you for the response and provide the detail.
Now i'm Looking Aimeos-database. Architecture https://aimeos.org/fileadmin/download/A ... abase.svgz
Can you please provide detail relationship Between
  • Product
  • Price
  • Media
  • Attribute
How can i get All the detail by of the product . It would be grate if you provide SQL Query or idea of getting all the detail by SQL Query
Post by aimeos » 08 Feb 2020, 08:33
Do not use SQL to retrieve the data, use the product manager instead:
https://aimeos.org/docs/Developers#Managers_and_items
$manager = \Aimeos\MShop::create( $context, 'product' );
$items = $manager->searchItems( $search, ['attribute', 'media', 'price', 'text'] );
foreach( $items as $item ) {
	$attributes = $item->getRefItems( 'attribute' );
	$images = $item->getRefItems( 'media', 'default' );
	$prices = $item->getRefItems( 'price', 'default', 'default' );
	$name = $item->getRefItems( 'text', 'name' );
