Email not receiving on order [Customer and Site Owner]
TYPO3 CMS 9.5.9
Aimeos 19.10.4
When customer Order Site owner and Customer both not receiving Email. Email is working on server Direct inquiry email is receiving both side.
Previously With Aimeos 19.10.2 Stable Version working after upgrading the 19.10.4 not working.
According to You Suggestion Create scheduler Still not working. [Page ID 26 = Checkout]
Execution of task "Aimeos Shop advanced scheduler (aimeos)" failed with the following message: No domain record in root page or SCHEDULER_HTTP_HOST env variable found
FYI- Order Export scheduler Is working
Previously without scheduler is working.
Kindly provide detail is this bug?
How to identify this problem.
Aimeos 19.10.4
- Casmart TYPO3 CMS 9 5 9 .png (48.9 KiB) Viewed 1058 times
Re: Email not receiving on order [Customer and Site Owner]
You have to set the correct page IDs in the corresponding fields. Furthermore, you need to make sure you have a domain entry in the TYPO3 root page (page with globe symbol in the page tree)
