CSV Import - Products
Hello im new here
i made a demo shop setup and want to import my products
but i dont understand how to do that
as far i understand i have to setup a sheduler job "product import csv" to do the import.
where do i have to put this configuration?:
controller/jobs/product/import/csv/location = <absolute path to the directory with the file>
controller/jobs/product/import/csv/skip-lines = 1
in sheduler also?
the csv setup configuration is stored here right?
/httpdocs/typo3conf/ext/aimeos/Resources/Private/Extensions/ai-controller-jobs/controller/common/src/Controller/Common/Product/Import/Csv/base.php
if i am wrong... can someone write me a small explanation how to do that, where to insert the configuration lines, where to store the csv file and so on... i tryed to read the documentation but i dont understand where i have to do this configurations
and how to execute the import.
I would be very thankful if someone could write a small guide (maybe some screenshots also)
Thank you
in sheduler also?
Thank you
Re: CSV Import - Products
In the scheduler task you add for the product import, there's a TSConfig field at the bottom. There you have to enter the configuration that should be available for the import. Remember, that TypoScript has a slightly different syntax:
controller.jobs.product.import.csv.location = /path/to/your/directory/with/csv/files
There's the default configuration. You can also add a custom configuration in the TSConfig field, e.g.
controller.jobs.product.import.csv.mapping {
item {
0 = product.code
media {
1 = media.url
We explain what you have to do an you write the guide afterwards. Deal?
delete
If you use Zip files, your configuration must be e.g.:
Important is that the location contains the ZIP file name.
controller.jobs.product.import.csv.container.type = Zip
controller.jobs.product.import.csv.container.content = CSV
controller.jobs.product.import.csv.location = /httpdocs/csvfiles/product.zip
delete
In the admin interface is a "Log" panel available (extended left navigation bar) where you can see everything that has happened.
ok the import works, here is a small guide:
1. make a Scheduler Task Class "Aimeos Shop advanced scheduler (aimeos)" ...Jobs "Product import CSV" like in the screenshot below.
2. use this TypoScript configuration:
controller.jobs.product.import.csv.skip-lines = 1
controller.common.product.import.csv.separator = ,
container.type = Directory
location = /var/www/vhosts/abc123.server.name12.de/httpdocs/csvfiles/
mapping {
item {
0 = product.code
1 = product.label
2 = product.type
3 = product.status
text {
4 = text.type
5 = text.content
6 = text.type
7 = text.content
media {
8 = media.url
price {
9 = price.currencyid
10 = price.quantity
11 = price.value
12 = price.taxrate
catalog {
13 = catalog.code
14 = catalog.lists.type
stock {
15 = stock.stocklevel
16 = stock.type
17 = stock.typeid
18 = stock.dateback
3. create a csv file with your products formated like this "id","name","type","status"......
Example: (copy+paste the csv example in a textfile and save the textfile as products.csv (convert the csv file into UTF8 with help of notepad++ for example if you have product names with letter äöü or other strange letters )):
csv file:
"product.code","product.label","product.type","product.status","text.type","text.content","text.type","text.content","media.url","price.currencyid","price.quantity","price.value","price.taxrate","catalog.code","catalog.lists.type","stock.stocklevel","stock.type","stock.typeid","stock.dateback"
"9998","9998 - name of the Product 1","default","1","name","9998 - name of the Product 1","long","9998 - name of the Product 1","path_to_the_image.jpg","EUR","1","3.5","19.00","Existing Category 1","default","","","default",""
"9999","9999 - name of the Product 2","default","1","name","9999 - name of the Product 2","long","9999 - name of the Product 2","path_to_the_image.jpg","EUR","1","7.2","19.00","Existing Category 2","default","","","default",""
4. put the csv file into the configured folder on your fileserver /var/www/vhosts/abc123.server.name12.de/httpdocs/csvfiles/
5. Execute the Sheduler Task (press play button)
Screenshot of the backend configuration:
mapping {
item {
0 = product.code
1 = product.label
2 = product.type
3 = product.status
text {
4 = text.type
5 = text.content
6 = text.type
7 = text.content
media {
8 = media.url
price {
10 = price.quantity
11 = price.value
12 = price.taxrate
catalog {
13 = catalog.code
stock {
16 = stock.type
17 = stock.typeid
18 = stock.dateback
csv file:
- guidetypo3gui.png (82.24 KiB) Viewed 6779 times
- SinanSakic
it still doesn't work for me.
I work with Typo3 on localhost.
I think the absolute path is wrong, but it doesn't have to be.
After I start the scheduler manually, a green bar appears with
"Executed: Aimeos Shop scheduler (aimeos) "and no entry in the log file.
Where could I look for the mistake?
I place the upload-file in:
C:/xampp/htdocs/gourmets/uploads
What is the right absolute path to the file now?
My vhost.conf:
<VirtualHost *:80>
DocumentRoot "C:/xampp/htdocs/gourmets"
ServerName gourmets.localhost
<Directory "C:/xampp/htdocs/gourmets">
Options Indexes FollowSymLinks MultiViews
AllowOverride All
Order Deny,Allow
Allow from all
Require all granted
</Directory>
</VirtualHost>
httpd.conf
/etc/hosts file:
127.0.0.1 gourmets.localhost
Thank you to All, also previous posts.
My vhost.conf:
<VirtualHost *:80>
AllowOverride All
Order Deny,Allow
Allow from all
Require all granted
</Directory>
</VirtualHost>
httpd.conf
/etc/hosts file:
- SinanSakic
And if I try with following TS Code:
location =C:\xampp\htdocs\gourmets\uploads\
mapping {
item {
0 = product.code
I got this log info in Aimeos-area:
Product import error: Required configuration for "controller/jobs/product/import/csv/location" is missing
mapping {
item {
0 = product.code
