Error setting up shop
First of all, Hi! I'm Edu, from Spain.
This morning I've started installing the Laravel package on a existing laravel proyect. I've edited the users table to comply with the requirements and almost everything was working. (I couldn't edit users, I had a conflict with the 'status' user field).
When I solved that issue, I tried to set up the proyect again but I can't stop seeing this error:
Linux machine
Laravel 5.8
I've tried Aimeos 2019.10 and 2020.01
PHP 7.2.27
I need some help to figure this error out.
Thanks in advance.
[vagrant@homestead:~/suitacademystudents$ php artisan aimeos:setup --option=setup/default/demo:1 -v
Initializing or updating the Aimeos database tables for site "default"
Add new type columns
Checking table "mshop_attribute": OK
Checking table "mshop_attribute_list": OK
Checking table "mshop_attribute_property": OK
Checking table "mshop_catalog_list": OK
Checking table "mshop_customer_list": OK
Checking table "mshop_customer_property": OK
Checking table "mshop_media": OK
Checking table "mshop_media_list": OK
Checking table "mshop_media_property": OK
Checking table "mshop_plugin": OK
Checking table "mshop_price": OK
Checking table "mshop_price_list": OK
Checking table "mshop_product": OK
Checking table "mshop_product_list": OK
Checking table "mshop_product_property": OK
Checking table "mshop_service": OK
Checking table "mshop_service_list": OK
Checking table "mshop_stock": OK
Checking table "mshop_supplier_list": OK
Checking table "mshop_tag": OK
Checking table "mshop_text": OK
Checking table "mshop_text_list": OK
Drop old unique indexes
Migrate typeid to type
Update attribute "key" columns
Checking table mshop_attribute OK
Renaming catalog index tables to index
Checking table "mshop_catalog_index_attribute" OK
Checking table "mshop_catalog_index_catalog" OK
Checking table "mshop_catalog_index_price" OK
Checking table "mshop_catalog_index_text" OK
Migrating configuration keys in coupon tables done
Migrate mshop_index_text table engine to InnoDB OK
Prepare mshop_index_price table for simplification OK
Prepare mshop_index_text table for simplification OK
Remove mshop_locale char constraints
Checking constraint for "langid" OK
Checking constraint for "currencyid" OK
Adding warehouse code to order base product table done
Adding tax column to order tables
Checking table "mshop_order_base_product": OK
Checking table "mshop_order_base_service": OK
Checking table "mshop_order_base": OK
Rename "prodid" to "parentid" in table "mshop_product_stock"
Checking column "prodid" OK
Migrating product property domain to "product" OK
Changing warehouseid column in mshop_product_stock OK
Rename warehouse table
Drop "mshop_product_stock.fk_msprost_whid" OK
Drop "mshop_product_stock.fk_msprost_stock_warehouseid" OK
Rename "mshop_product_stock.wareshouseid" OK
Rename "mshop_product_stock_wareshouse" OK
Move stock tables to own domain
Checking "mshop_product_stock" OK
Checking "mshop_product_stock_type" OK
Ensure unique codes in mshop_service done
Migrate product code in stock table
Remove index "unq_msprost_sid_pid_tid" OK
Remove index "unq_msprost_sid_pid_wid" OK
Migrate to column "productcode" OK
Remove foreign key "fk_msprost_parentid" OK
Remove foreign key "fk_msprost_pid" OK
Remove column "parentid" OK
Clear property "key" columns
Checking table mshop_attribute_property OK
Checking table mshop_customer_property OK
Checking table mshop_media_property OK
Checking table mshop_price_property OK
Checking table mshop_product_property OK
Update "siteid" columns
Checking table mshop_attribute_type OK
Checking table mshop_attribute_list_type OK
Checking table mshop_attribute_property_type OK
Checking table mshop_attribute_list OK
Checking table madmin_cache_tag OK
Checking table madmin_cache OK
Checking table mshop_catalog_list_type OK
Checking table mshop_catalog_list OK
Checking table mshop_catalog OK
Checking table mshop_coupon_code OK
Checking table mshop_coupon OK
Checking table mshop_customer_list_type OK
Checking table mshop_customer_property_type OK
Checking table mshop_customer_group OK
Checking table mshop_customer_list OK
Checking table mshop_customer_address OK
Checking table mshop_customer OK
Checking table madmin_job OK
Checking table mshop_locale_site OK
Checking table mshop_locale OK
Checking table madmin_log OK
Checking table mshop_media_type OK
Checking table mshop_media_list_type OK
Checking table mshop_media_property_type OK
Checking table mshop_media_list OK
Checking table mshop_media OK
Checking table mshop_order_base_product_attr OK
Checking table mshop_order_base_service_attr OK
Checking table mshop_order_base_coupon OK
Checking table mshop_order_base_product OK
Checking table mshop_order_base_service OK
Checking table mshop_order_base_address OK
Checking table mshop_order_base OK
Checking table mshop_order_status OK
Checking table mshop_order OK
Checking table mshop_plugin_type OK
Checking table mshop_plugin OK
Checking table mshop_price_type OK
Checking table mshop_price_list_type OK
Checking table mshop_price_list OK
Checking table mshop_price OK
Checking table mshop_index_attribute OK
Checking table mshop_index_catalog OK
Checking table mshop_index_price OK
Checking table mshop_index_supplier OK
Checking table mshop_index_text OK
Checking table mshop_product_list_type OK
Checking table mshop_product_property_type OK
Checking table mshop_product_type OK
Checking table mshop_product_list OK
Checking table mshop_product OK
Checking table mshop_service_type OK
Checking table mshop_service_list_type OK
Checking table mshop_service_list OK
Checking table mshop_service OK
Checking table mshop_stock_type OK
Checking table mshop_stock OK
Checking table mshop_subscription OK
Checking table mshop_supplier_list_type OK
Checking table mshop_supplier_list OK
Checking table mshop_supplier_address OK
Checking table mshop_supplier OK
Checking table mshop_tag_type OK
Checking table mshop_tag OK
Checking table mshop_text_type OK
Checking table mshop_text_list_type OK
Checking table mshop_text_list OK
Checking table mshop_text OK
Moving product tag tables to own domain
Moving table "mshop_product_tag_type" OK
Moving table "mshop_product_tag" OK
Rename "refid" to "parentid" in table "users_address"
Checking column "refid" OK
Remove left over Laravel user references
Remove records from users_address OK
Remove records from users_list OK
Remove records from users_property OK
Update Laravel "siteid" columns
Checking table users_list_type OK
Checking table users_property_type OK
Checking table users_property OK
Checking table users_list OK
Checking table users_address OK
Checking table users OK
Add new type columns for Laravel
Checking table "users_list": OK
Checking table "users_property": OK
Drop old unique indexes for Laravel
Migrate typeid to type for Laravel
Creating base tables
Using schema from locale.php
Checking table "mshop_locale_currency": OK
Checking table "mshop_locale_language": OK
Checking table "mshop_locale_site": done
Checking table "mshop_locale": OK
Using schema from attribute.php
Checking table "mshop_attribute_type": done
Checking table "mshop_attribute": done
Checking table "mshop_attribute_list_type": done
Checking table "mshop_attribute_list": done
Checking table "mshop_attribute_property_type": done
Checking table "mshop_attribute_property": done
Using schema from customer.php
Checking table "mshop_customer": OK
Checking table "mshop_customer_address": OK
Checking table "mshop_customer_group": done
Checking table "mshop_customer_list_type": done
Checking table "mshop_customer_list": done
Checking table "mshop_customer_property_type": done
Checking table "mshop_customer_property": done
Checking table "users": done
Checking table "users_address": OK
Checking table "users_list_type": done
Checking table "users_list": done
Checking table "users_property_type": done
Checking table "users_property": done
Using schema from media.php
Checking table "mshop_media_type": done
Checking table "mshop_media": done
Checking table "mshop_media_list_type": done
Checking table "mshop_media_list": done
Checking table "mshop_media_property_type": done
Checking table "mshop_media_property": done
Using schema from order.php
Checking table "mshop_order_base": done
Checking table "mshop_order_base_address": done
Checking table "mshop_order_base_product": done
Checking table "mshop_order_base_product_attr": done
Checking table "mshop_order_base_service": done
Checking table "mshop_order_base_service_attr": done
Checking table "mshop_order_base_coupon": done
Checking table "mshop_order": done
Checking table "mshop_order_status": done
Using schema from plugin.php
Checking table "mshop_plugin_type": done
Checking table "mshop_plugin": done
Using schema from price.php
Checking table "mshop_price_type": done
Checking table "mshop_price": done
Checking table "mshop_price_list_type": done
Checking table "mshop_price_list": done
Checking table "mshop_price_property_type": done
Checking table "mshop_price_property": done
Using schema from product.php
Checking table "mshop_product_type": done
Checking table "mshop_product": done
Checking table "mshop_product_list_type": done
Checking table "mshop_product_list": done
Checking table "mshop_product_property_type": done
Checking table "mshop_product_property": done
Using schema from stock.php
Checking table "mshop_stock_type": done
Checking table "mshop_stock": done
Using schema from service.php
Checking table "mshop_service_type": done
Checking table "mshop_service": done
Checking table "mshop_service_list_type": done
Checking table "mshop_service_list": done
Using schema from supplier.php
Checking table "mshop_supplier": done
Checking table "mshop_supplier_address": OK
Checking table "mshop_supplier_list_type": done
Checking table "mshop_supplier_list": done
Using schema from text.php
Checking table "mshop_text_type": done
Checking table "mshop_text": done
Checking table "mshop_text_list_type": done
Checking table "mshop_text_list": done
Using schema from coupon.php
Checking table "mshop_coupon": OK
Checking table "mshop_coupon_code": done
Using schema from catalog.php
Checking table "mshop_catalog": done
Checking table "mshop_catalog_list_type": done
Checking table "mshop_catalog_list": done
Using schema from tag.php
Checking table "mshop_tag_type": done
Checking table "mshop_tag": done
Using schema from index.php
Checking table "mshop_index_attribute": done
Checking table "mshop_index_catalog": done
Checking table "mshop_index_price": OK
Checking table "mshop_index_supplier": done
Checking table "mshop_index_text": OK
Using schema from subscription.php
Checking table "mshop_subscription": done
Remove ctime/editor from index tables
Checking table "mshop_index_attribute": OK
Checking table "mshop_index_catalog": OK
Checking table "mshop_index_supplier": OK
Migrating preview column in media table done
Add locale data for languages and currencies
Adding data for MShop locale languages
Aimeos\MW\DB\Exception : SQLSTATE[42S02]: Base table or view not found: 1146 Table 'suitacademystudents.madmin_log' doesn't exist:
INSERT INTO "madmin_log" (
"facility", "timestamp", "priority", "message", "request", "siteid"
) VALUES (
at /home/vagrant/suitacademystudents/vendor/aimeos/aimeos-core/lib/mwlib/src/MW/DB/Statement/DBAL/Prepared.php:77
73| {
74| try {
75| $stmt = $this->exec();
76| } catch( \PDOException $e ) {
> 77| throw new \Aimeos\MW\DB\Exception( $e->getMessage() . ': ' . $this->sql, $e->getCode() );
78| }
79|
80| return new \Aimeos\MW\DB\Result\PDO( $stmt );
81| }
Exception trace:
1 Aimeos\MW\DB\Statement\DBAL\Prepared::execute()
/home/vagrant/suitacademystudents/vendor/aimeos/aimeos-core/lib/mshoplib/src/MAdmin/Log/Manager/Standard.php:297
2 Aimeos\MAdmin\Log\Manager\Standard::saveItem(Object(Aimeos\MAdmin\Log\Item\Standard))
/home/vagrant/suitacademystudents/vendor/aimeos/aimeos-core/lib/mshoplib/src/MAdmin/Log/Manager/Standard.php:667
3 Aimeos\MAdmin\Log\Manager\Standard::log("{"time":0.38504600524902344,"class":"Aimeos\\MShop\\Locale\\Manager\\Language\\Standard","stmt":"\n\t\t\t\t\t\tSELECT DISTINCT \n\t\t\t\t\t\t\tmlocla.\"id\" AS \"locale.language.id\", mlocla.\"label\" AS \"locale.language.label\",\n\t\t\t\t\t\t\tmlocla.\"status\" AS \"locale.language.status\", mlocla.\"mtime\" AS \"locale.language.mtime\",\n\t\t\t\t\t\t\tmlocla.\"editor\" AS \"locale.language.editor\", mlocla.\"ctime\" AS \"locale.language.ctime\"\n\t\t\t\t\t\tFROM \"mshop_locale_language\" AS mlocla\n\t\t\t\t\t\tWHERE 1 = 1\n\t\t\t\t\t\tORDER BY mlocla.\"id\" ASC\n\t\t\t\t\t\tLIMIT 2147483647 OFFSET 0\n\t\t\t\t\t"}", "core/sql")
/home/vagrant/suitacademystudents/vendor/aimeos/aimeos-core/lib/mshoplib/src/MShop/Locale/Manager/Language/Standard.php:661
4 Aimeos\MShop\Locale\Manager\Language\Standard::getSearchResults(Object(Aimeos\MW\DB\Connection\DBAL), "
SELECT DISTINCT
mlocla."id" AS "locale.language.id", mlocla."label" AS "locale.language.label",
mlocla."status" AS "locale.language.status", mlocla."mtime" AS "locale.language.mtime",
mlocla."editor" AS "locale.language.editor", mlocla."ctime" AS "locale.language.ctime"
FROM "mshop_locale_language" AS mlocla
WHERE 1 = 1
ORDER BY mlocla."id" ASC
/home/vagrant/suitacademystudents/vendor/aimeos/aimeos-core/lib/mshoplib/src/MShop/Locale/Manager/Language/Standard.php:596
5 Aimeos\MShop\Locale\Manager\Language\Standard::searchItems(Object(Aimeos\MW\Criteria\SQL), [])
/home/vagrant/suitacademystudents/vendor/aimeos/aimeos-core/lib/mshoplib/src/MShop/Common/Manager/Decorator/Depth.php:59
6 Aimeos\MShop\Common\Manager\Decorator\Depth::searchItems(Object(Aimeos\MW\Criteria\SQL))
/home/vagrant/suitacademystudents/vendor/aimeos/aimeos-core/lib/mshoplib/setup/MShopAddLocaleData.php:191
7 Aimeos\MW\Setup\Task\MShopAddLocaleData::addLocaleLanguageData(Object(Aimeos\MShop\Common\Manager\Decorator\Depth))
/home/vagrant/suitacademystudents/vendor/aimeos/aimeos-core/lib/mshoplib/setup/MShopAddLocaleLangCurData.php:50
8 Aimeos\MW\Setup\Task\MShopAddLocaleLangCurData::migrate()
/home/vagrant/suitacademystudents/vendor/aimeos/aimeos-core/lib/mwlib/src/MW/Setup/Manager/Multiple.php:114
9 Aimeos\MW\Setup\Manager\Multiple::migrateTasks()
/home/vagrant/suitacademystudents/vendor/aimeos/aimeos-core/lib/mwlib/src/MW/Setup/Manager/Multiple.php:110
10 Aimeos\MW\Setup\Manager\Multiple::migrateTasks()
11 Aimeos\MW\Setup\Manager\Multiple::migrateTasks()
12 Aimeos\MW\Setup\Manager\Multiple::migrateTasks()
13 Aimeos\MW\Setup\Manager\Multiple::migrateTasks()
/home/vagrant/suitacademystudents/vendor/aimeos/aimeos-core/lib/mwlib/src/MW/Setup/Manager/Multiple.php:82
14 Aimeos\MW\Setup\Manager\Multiple::migrate(Object(Aimeos\MW\Setup\Task\MShopAddAttributeData))
/home/vagrant/suitacademystudents/vendor/aimeos/aimeos-laravel/src/Aimeos/Shop/Command/SetupCommand.php:74
15 Aimeos\Shop\Command\SetupCommand::handle()
/home/vagrant/suitacademystudents/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php:32
16 call_user_func_array([])
17 Illuminate\Container\BoundMethod::Illuminate\Container\{closure}()
/home/vagrant/suitacademystudents/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php:90
18 Illuminate\Container\BoundMethod::callBoundMethod(Object(Illuminate\Foundation\Application), Object(Closure))
/home/vagrant/suitacademystudents/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php:34
19 Illuminate\Container\BoundMethod::call(Object(Illuminate\Foundation\Application), [])
/home/vagrant/suitacademystudents/vendor/laravel/framework/src/Illuminate/Container/Container.php:576
20 Illuminate\Container\Container::call()
/home/vagrant/suitacademystudents/vendor/laravel/framework/src/Illuminate/Console/Command.php:183
21 Illuminate\Console\Command::execute(Object(Symfony\Component\Console\Input\ArgvInput), Object(Illuminate\Console\OutputStyle))
/home/vagrant/suitacademystudents/vendor/symfony/console/Command/Command.php:255
22 Symfony\Component\Console\Command\Command::run(Object(Symfony\Component\Console\Input\ArgvInput), Object(Illuminate\Console\OutputStyle))
/home/vagrant/suitacademystudents/vendor/laravel/framework/src/Illuminate/Console/Command.php:170
23 Illuminate\Console\Command::run(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
/home/vagrant/suitacademystudents/vendor/symfony/console/Application.php:1001
24 Symfony\Component\Console\Application::doRunCommand(Object(Aimeos\Shop\Command\SetupCommand), Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
/home/vagrant/suitacademystudents/vendor/symfony/console/Application.php:271
25 Symfony\Component\Console\Application::doRun(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
/home/vagrant/suitacademystudents/vendor/symfony/console/Application.php:147
26 Symfony\Component\Console\Application::run(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
/home/vagrant/suitacademystudents/vendor/laravel/framework/src/Illuminate/Console/Application.php:90
27 Illuminate\Console\Application::run(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
/home/vagrant/suitacademystudents/vendor/laravel/framework/src/Illuminate/Foundation/Console/Kernel.php:133
28 Illuminate\Foundation\Console\Kernel::handle(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
/home/vagrant/suitacademystudents/artisan:37
Laravel 5.8
PHP 7.2.27
Thanks in advance.
Re: Error setting up shop
Maybe an error occured before and it should be written into the madmin_log table (which doesn't exist yet). Can you change that method to "getPostDependencies" and run "./artisan aimeos:setup" afterwards:
https://github.com/aimeos/aimeos-core/b ... in.php#L23
Thanks fot the quick answer. I'll try what you say and let you know.
I had installed 2019 without issues, when I upgraded to 2020 I had the same issue as OP. This is what solved it. Thank you.aimeos wrote: ↑05 Mar 2020, 14:37 Maybe an error occured before and it should be written into the madmin_log table (which doesn't exist yet). Can you change that method to "getPostDependencies" and run "./artisan aimeos:setup" afterwards:
