Generate Previews For Product That Created Form Custom Controller
I want to generate media previews for the product that I have created from my custom controller. Means right after the product creation.
Please guide me about this issue.
Re: Generate Previews For Product That Created Form Custom Controller
Use the scale() method of the media controller:
https://github.com/aimeos/ai-controller ... d.php#L179
$cntl = \Aimeos\Controller\Common\Media\Factory::create( $context );
$mediaItem = $cntl->scale( $mediaItem );
