Getting order details
adityabanerjee
Post by adityabanerjee » 17 Apr 2020, 11:59
Hi Aimeos,
I want to get the order details. I want to get the order details in a controller method of Laravel and pass it to a view. Could you please tell me how could I get the order details in the Laravel controller method? What would be the query? Is there a built-in method to get order details? Please assist.
Thank you
Aditya Banerjee
Re: Getting order details
Post by aimeos » 19 Apr 2020, 07:44
You can retrieve orders using the Aimeos order frontend controller if you are logged in as the customer who have placed the order. Use these code for example (2020.x version):
// get the context which includes the database connection
$context = app( 'aimeos.context' )->get();
// create the order frontend controller
$cntl = \Aimeos\Controller\Frontend::create( $context, 'order' );
// pass the parts you want to fetch for the orders:
$cntl->uses( ['order/base', 'order/base/address', 'order/base/coupon', 'order/base/product', 'order/base/service'] );
// search() returns the order items
foreach( $cntl->search() as $item ) {
 // getBaseItem() returns the basket
  $base = $item->getBaseItem();
You can find the interface for the objects here:
- https://github.com/aimeos/ai-controller ... /Iface.php
- https://github.com/aimeos/aimeos-core/b ... /Iface.php
