Order.id not found
adityabanerjee
Order.id not found
Post by adityabanerjee » 17 Apr 2020, 16:56
Hi Aimeos,
I am trying to get the order by id i.e order id 1. But it is throwing an exception -:
Aimeos\MShop\Exception
Item with ID "1" in "order.id" not found
My code-:
$context = app( 'aimeos.context' )->get();
$cntl = \Aimeos\Controller\Frontend::create( $context, 'order' )->uses(
['order/base', 'order/base/address', 'order/base/coupon',
'order/base/product', 'order/base/service'] );
echo "<pre>";
print_r($cntl->get('1'));
die;
I have checked that the order with order id 1 exists and also checked the database table.
Re: Order.id not found
Post by aimeos » 19 Apr 2020, 07:53
You must be logged in as customer who created the order to retrieve its order details.
unknow76616
Post by unknow76616 » 06 Jun 2024, 10:38
//in webhook contraller
$context = app('aimeos.context')->get();
$manager = \Aimeos\MShop::create($context, 'order');
$order = $manager->get($orderId);
i still got "order.id" not found ( even id is exsit )
Is it possible to retrieve an order without requiring user login? , Because it's system callbacks ( webhook )
Post by aimeos » 07 Jun 2024, 10:06
alababdiy wrote: 06 Jun 2024, 10:38
Your code is correct and should return the order if the ID exists and if the site ID matches with the one from the context locale object (check the last condition).
unknow76616
Post by unknow76616 » 08 Jun 2024, 09:05
Is there a way to force $context to set a specific site ID so I can limit my search to orders within that site or all sites?
i try to make reset order SiteID on $context by this line
$context->setLocale( app( 'aimeos.locale' )->getBackend( $context, $siteID ) );
but still showing Item with ID "XXX" in "order.id" not found
[ UPDATE , SOLVED ]
I should pass $siteCode instead $siteID :
$context->setLocale( app( 'aimeos.locale' )->getBackend( $context, $siteCode ) );
